It is currently Mon Nov 16, 2026 12:03 am
PostPosted: Sun Oct 18, 2020 11:38 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Bought a cool '64 wagon that has a Clifford intake and headers. No carb. I have been doing a lot of searching on the topic, but there are still some questions I would like answers to.
1. What is the BEST carb for a Clifford manifold?
2. I have a BBD, but adapters for the intake are Weber size. Would like to stay w/ BBD
3. Will a BBD flow enough for the Clifford intake to work properly?
4. Will a 4-2 carb adaptor work on the Clifford?
5. Any advice on Redline Webers?
Thanks for your expertise,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Sun Oct 18, 2020 1:27 pm
The TransDapt or Mr. Gasket 2 to 4 bbl adapter plates from the parts store or Summit should work, maybe with a little filing out of holes to bolt the Clifford. That will allow bolt up of your BBD. That is a great carb and will work fine with the Clifford. That's what I would do, assuming no other internal engine mods (or mild ones).
PostPosted: Sun Oct 18, 2020 3:47 pm
Thanks, Lou. That was what I was looking for.
Joe
Joe Hoppe
PostPosted: Mon Oct 19, 2020 4:50 am
Sure. Make sure you hook up a working kickdown linkage to the trans. The cable kits from Lokar or similar work pretty well for this. With the clifford intake, you will likely not be able to use the factory kickdown linkage, or will need to work to adapt it. As a stopgap, you can wire or zip tied the kickdown lever on the trans back about 2/3 of the way through its travel. If you do not hook it up at all, you will likely burn up the clutches in your transmission! If you have a manual transmission, you are good to go.
PostPosted: Mon Oct 19, 2020 11:23 am
Will do w/ those linkages.
Joe
Joe Hoppe
