It is currently Mon Nov 16, 2026 5:44 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Re: Heat Riser Valve
PostPosted: Thu Oct 29, 2020 10:36 am
[quote="cpslntdchrg"]Or you might be talking about the EGR
You were right, it's an EGR valve, which I thought was only found at the valve cover.
PostPosted: Thu Oct 29, 2020 11:43 am
Good we found what the vacuum port was for...
And... on the valve cover... you should have a PCV valve... that is good to have and should be in operating conditions.
Good luck solving your lean conditions. Using larger diameter jets makes sense to me.
/6 Dodge Charger 69
PostPosted: Fri Oct 30, 2020 2:19 pm
Oh right, PCV is what I was thinking of, back to my ABC's!
Users browsing this forum: Ahrefs [Bot] and 5 guests
