It is currently Sun Nov 15, 2026 7:31 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Oct 25, 2020 10:42 am
Car Model: 1960 Dart Seneca
Lou: The radiator is original to the car by all appearances. It has been totally gone through by a local radiator shop (Gold Star - boiled and rodded-out) and was pronounced fit by them. My son was working on it yesterday with my buddy and they seemed to have resolved it somehow (I was home preparing for today's snowstorm). They installed a thermostat with a "tickler" (a Subaru part, actually, that fit perfectly) and then had an event of some type that resulted in a fairly explosive boil-over. Upon refilling, it proceeded to make a number of rather alarming noises (they mentioned thumping and cracking sounds!) and then it began to run exactly at 180 degrees. I'm guessing that they purged an air bubble. Perhaps we've exercized that particular demon?
PostPosted: Thu Oct 29, 2020 4:12 pm
Was out driving the car today. Zero heating issues. It seems that once you purge the air from the cooling system, you're all set.
PostPosted: Thu Oct 29, 2020 9:02 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
Glad that you expunged the "demon" air bubble, it seems. The shot of your dash brought back some memories of driving my Dad's '60 Fury wagon in the 60's. Also, to a lesser extent, my '59 DeSoto daily driver a bit later. Beautiful slant you have prepared! Thanks for sharing.
There's a guy, actually a group, on Youtube, Coldwarmotors in Alberta, Ca., that's redoing a '60 Fury. Just the entire body and trim so far. They work on older cars and come and go on the Fury, so you have to look over the videos to find it.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
PostPosted: Fri Oct 30, 2020 10:54 am
hank2: Thanks! It did turn out pretty nice. My son has actually been in contact with Scott (the proprietor of Cold War Motors) and has gotten some critical parts from him. That 60 Fury build has been quite educational for both my boy and I to watch, as the donor chassis started life as a 60 Dodge Dart Pioneer (I believe).
The headlight trim used here came from that 60 Dart. This is post-test drive yesterday.
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
