It is currently Mon Nov 09, 2026 12:17 pm
 Post subject: Ignition switch pigtail
PostPosted: Tue Dec 01, 2020 8:46 pm
Car Model: 1965 A100 pickup
Hey guys, I have a ‘65 A100, and new a new ignition switch pigtail. Mine is cracked and I’ve been searching everywhere and can’t find one. Anyone with a source for a replacement pigtail?
PostPosted: Wed Dec 02, 2020 7:04 am
Mod's should probably move this to the electrical forum.
Those switches are probably pretty simple if it's anything like a 64 dart or polara.
It would be helpful for you to post a picture of what you need in case the configuration of the wire / plugs is not the same as the other cars of the era.
Additionally if you can't come up with one you can also just put insulated female spade terminals on the ends of your existing wires and connect to your switch.
PostPosted: Wed Dec 02, 2020 5:33 pm
Thanks Greg for the response. I’d kinda like to stay with the stock setup if I can. Not in a big hurry, and have a few requests out there. Hopefully someone can help me out. Thanks,Steve
