It is currently Fri Nov 13, 2026 10:01 pm
PostPosted: Fri Jul 30, 2010 11:52 am
Car Model: Toad Wagon
if you put a small gear on cam and not a smaller on crank....you have changed ratio .... as engine turns it will change cam timing...wont work
I just read this thread and was wondering when someone'd get around to mentioning the basics, that a tooth count of 2 to 1 is requisite. A 50 tooth cam sprocket'd need a 25 crank, and a 48'd need a 24.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sat Jul 31, 2010 7:01 am
You mention that you were gettin Cloyes chains; I ran into that same problem a few years ago buying Cloyes T chains for a 318. I went thru a couple of them; both too sloppy for my liking; so I returned the 2nd one to Useless Zone then went around the corner some place else, and bought an Edelbrock, double roller as the Cloyes units were.
The Edelbrock was a much better fit.
I'd used Cloyes parts before but like every other manufacturing company these days "they don't make em like they used to".
the particular Cloyes chains I had bought weren't the "performance" ones but rather a "factory heavyduty replacement" meaning it was meant for the cop cars and other "premium" smallblocks that originally came with a double roller.
PostPosted: Sat Dec 12, 2020 2:01 pm
Wow! I just saw this in my searching! Has anyone else seen this different tooth count set? Doesn't look like the poster ever followed up.
Having problems with a set in my truck. Although I am not at all sure I want an odd ball set installed for the future.
PostPosted: Sun Dec 13, 2020 6:06 am
http://www.romacusa.com/products.html
PostPosted: Sun Dec 13, 2020 6:11 am
http://www.romacusa.com/tech_timing_sets.html
PostPosted: Sun Dec 13, 2020 6:18 am
http://www.romacusa.com/downloads/Sprocket_DataUS.pdf
PostPosted: Sun Dec 13, 2020 6:21 am
measure center to center ,data in pdf 5.125
PostPosted: Sun Dec 13, 2020 7:14 am
https://www.slantsix.org/forum/viewtopic.php?t=24900
PostPosted: Sun Dec 13, 2020 2:38 pm
Car Model: 1965 A100 pickup
Getting close to putting my /6 back together. How much timing chain slack is “too much”?
PostPosted: Mon Dec 14, 2020 7:23 am
Then there's a soultion that this guy is trying:
https://www.slantsix.org/forum/viewtopi ... &start=216
and this guy:
https://www.forabodiesonly.com/mopar/th ... nt.432795/
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
