It is currently Tue Jun 16, 2026 5:10 am
 Post subject: Tf904 shift kit
PostPosted: Thu Dec 17, 2020 5:30 pm
I am researching what my plan will be on my transmission build
My ? Is with trans go kit stg2 vs stg3
I am wanting to know on stg 2 if I shift 1st to 2nd and run up the RPMs all the way up to 5000-6000
in the 1/8mile will it stay in 2nd or shift it self to drive ?
1963 Plymouth Valiant Wagon
 Post subject: Re: Tf904 shift kit
PostPosted: Thu Dec 17, 2020 7:03 pm
With either shift kit you can hold a gear as long as you want. If you want it to shift automatically at a certain RPM that's a little harder to dial in and you might end up changing governor weights.
PostPosted: Thu Dec 17, 2020 7:19 pm
I shift at 6300 with a 4.10 gear and 30" tires. I cross the 1/8th in 2nd. I go into high at the 1000' mark.
PostPosted: Thu Dec 17, 2020 7:40 pm
So if it will hold gear with stg 2 and I plan street // strip
Then stg 2 seams like a better way to go
Am I correct assuming this
PostPosted: Thu Dec 17, 2020 8:38 pm
I'll let others answer that. I never use the TransGo stuff.
PostPosted: Thu Dec 17, 2020 8:48 pm
What do you use ?
PostPosted: Fri Dec 18, 2020 11:07 am
I have Griner valve bodies in everything. My trans guy is the manufacturer now.
PostPosted: Fri Dec 18, 2020 3:58 pm
Stage 3 in Transgo is a full manual shift up an down. Put the shifter in d and it will try and take off in 3rd.
PostPosted: Fri Dec 18, 2020 5:07 pm
So for street strip not worried about street comfort or easy would you go stg 2 or stg 3
PostPosted: Sat Dec 19, 2020 10:15 am
If I were having a street car and running more than a couple hundred miles a year, I would probably go stage 2. It this is a race car, with high stall convertor, low gears......etc, and it is only going to get run on the road a few times a year then go for a stage 3. Just so long as you don't mind always shifting manually, up and down, and it will shift harsh.
