It is currently Fri Jan 30, 2026 4:58 pm
 Post subject: 8 inch Ford JFI
PostPosted: Mon Jan 04, 2021 7:36 am
I got me a 8 inch Ford rear awhile back. Just starting to work on it. Found some basic info, while doing research.
Mine still had the tag, and decoded to 1975-1977 Comet/Maverick (also 64-65 Falcon). Build date 8-4-75, 2.73 open. That has a width of 56.375 inches, spring perch width of 43 inch, 28 spline axles, brakes are 10x1 3/4 with a 5 on 4 1/2 bolt pattern.
Will be getting a 4.30 mini spool, for my 65 Valiant. Only $300 in it plus the brake parts. A lot cheaper the a 8 3/4.
There are quite a few 8 inch Ford rears that would work in a "A" body. Take your tape measure to the yard. Make sure you get the 5 lug rear from a V-8 car.
 Post subject: Re: 8 inch Ford JFI
PostPosted: Mon Jan 04, 2021 8:36 am
That’s what I have in the Duster with a 4.56 mini spool. Works great.
The first Duster we used a first gen Dakota rear. It was almost a bolt in as well.
PostPosted: Mon Jan 04, 2021 11:58 am
Car Model: Toad Wagon
Ditto, 4.56 & mini spool, in the 'Brick. Thinking about eventually going 8" for El Toad, but with the four spider version.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Mon Jan 04, 2021 1:48 pm
I was supprised at how many different vehicles had 8 inch rears that would work. Several models with only about 1 inch difference in total width (don't know about spring perchs). 56 3/8, 56 7/8, and 57 3/8 are some I found.
Just ordered brake parts, axle bearings, and seals from Rockauto. I am on hold with Summit for long wheel studs, as I'm typing this.
PostPosted: Mon Jan 04, 2021 1:52 pm
I put an 8" in my '72 Dart. Didn't even have to shorten the driveshaft, but that may have been because the oval track leaf springs I used pushed the axle back 1/2". The 28 spline axles are my only concern.
PostPosted: Mon Jan 04, 2021 2:00 pm
Yep. Maverick 8" in my Project V since 2003. Perfect width and no driveshaft cutting with stock 904 and rear springs.
PostPosted: Mon Jan 04, 2021 2:28 pm
Seems like a skookum affordable package for our cars.
What does the JFI refer to?
PostPosted: Mon Jan 04, 2021 3:29 pm
Just for information???
PostPosted: Mon Jan 04, 2021 7:24 pm
Yep
PostPosted: Tue Jan 05, 2021 6:12 pm
It's the Florida version of FYI. :mrgreen:
PostPosted: Wed Jan 06, 2021 3:53 am
Thanks Guys.
I have heard of FYI - I thought maybe JFI was some sort of Option or Ford Production code Like 2JZ, LS3, A833, RG, AHB or something like that.
Still learning new stuff every day.
PostPosted: Wed Jan 06, 2021 4:44 am
Hey, at my age, when you can't remember shortcuts, you make up your own. :?
PostPosted: Wed Jan 06, 2021 4:47 am
You people running 8 inch Fords, what did you use for wheel studs? I can't seem to find long studs with the correct size knurl (.545). I would rather not drill the holes oversize, for a larger knurl, if I don't have to.
PostPosted: Wed Jan 06, 2021 5:55 am
Mine had the longer studs when I bought the Duster from Norm ages ago. Sorry.
PostPosted: Wed Jan 06, 2021 9:40 am
You seem pretty sharp to me Charlie.
