It is currently Mon Oct 12, 2026 12:20 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page 1 2 3 Next
 Post subject: Roma's 74 Valiant
PostPosted: Sun Jan 10, 2021 8:32 am
Car Model: 74 Plymouth Valiant
My daughter is 2 years away from getting her license and wanted to get a project car that we could work on for the next 2 years. Enter the '74 Plymouth Valiant.
After we had it towed to our house, she couldn't wait to get into the driver's seat:
It didn't have a battery, so we bought one to see what problems we had just inherited. The engine bay was pretty dirty overall.
The radiator looked a bit corroded, so a flush was added to the to-do list:
We also saw this metal box with some sort of heavy resin leaking out of it. I later found out that it is a voltage regulator. We would need to order a new one (assuming this one has given up the ghost):
Here is Roma, pulling the spark plugs to look at them:
 Post subject: Re: Roma's 74 Valiant
PostPosted: Sun Jan 10, 2021 9:07 am
So far, here's where we are at:
With the battery installed, we tried to turn over the engine. The starter would engage for a partial rev and then grind. Or it would just grind. We pulled the starter (it was the original-style big body form). The teeth on the starter were rounded and several teeth on the torque converter were chipped. We decided to replace the starter with a mini-style and see if we could use the torque converter as-is (for now, at least). The new starter was installed and the engine would turn over without issue. I should note that the previous owner knew very little about the car and was selling it for his mother in-law, whose husband had purchased it new in 1974. He did mention that he couldn't get it running and that it might have "skipped a tooth". Here is Roma installing the new starter. Note that she's a bit camera shy :mrgreen:
We also checked the plugs. They were all very black. No signs of oil. However, when I looked up the part number (Autolite 25), these did not appear to be the correct size for this engine. We bought some Champion 7322's.
While pulling the plugs, we saw that the plug tube gaskets were shot. New ones were ordered.
After buying a new radiator cap to replace the existing broken one, we performed a pressure test on the coolant system and ended up with sticky green shoes for the effort. We tightened several hose clamps, but it looks like the water pump weep hole is leaking and the gasket is shot. A new pump, pump gasket, thermostat, and t-stat gasket were ordered. Eventually, when the engine is running and up to temperature, we will run a few cycles of coolant flush to de-corrode the system. We loosened the fan shroud and removed the fan yesterday. The thermostat was pulled and the water pump was pulled. A lot of pitting in the t-stat housing, engine block, and head was observed. We wire-brushed all surfaces to remove the gobs of red RTV and the old paper gaskets. Hopefully, we will get the new pump and t-stat installed today (although we may wait on the t-stat until after the flush is done). I'm doubting that the gasket will be enough to seal the pitting, so I may have to go back with gasket+RTV, which I hate doing. What RTV do people like?
When we removed the old voltage regulator, we saw that one end of the wire ended in a loose connector and the other wire went into a taped loom. Does anyone know where the connector end goes to?
Several vacuum lines were plugged or left disconnected, so I will have to see where they go back to. While investigating the carb fittings, I found that the choke linkage and vacuum kickdown were off or loose. I also found that the top butterfly was outright missing. The shaft was present but the plate and screws were gone. I believe that this is the choke butterfly, right? Anyone know where I can get a new one?
We also found that the engine mounts were completely disintegrated. New ones were ordered.
We sampled the trans fluid through the dipstick and sent it off to Blackstone Labs for analysis. I normally send all of my fluids off to them. The ATF looked reddish, and not burnt, so that's a good sign, but I'll let the Lab say for sure.
We did an oil change yesterday. As with the ATF, I took a sample for analysis. The oil looked dark. No off-smell nor any chocolate milk color, so that looks promising.
Today we plan to install the new water pump. While we are there, we will pull the timing cover and see what that looks like. And since we already have half of the accessories out of the way, we'll change the engine mounts, too. If we have time, and I go get a compression test kit, we will do a cylinder compression test, too.
Still to-do:
Replace water pump
Pull timing cover & check timing chain/gears
Compression test
Change plugs, wires, cap, rotor, coil. New gaskets for plug tubes, too
Motor (& trans) mounts
Coolant flush (remove corrosion)
ATF change
Check brakes, flush brake fluid
Fix carb
Fix lights & wiring
Lube chassis
Check suspension
Check u-joints & diff
Test alternator
Fix HVAC
Test (fix leak? power steering
Check valve lash
Check ignition timing
PostPosted: Sun Jan 10, 2021 5:55 pm
None of your images are working.
PostPosted: Mon Jan 11, 2021 8:39 am
Well, crap. They worked in the preview, but the links that I inserted must be temporary.
PostPosted: Mon Jan 11, 2021 10:49 am
Sunday was a busy day in the household, but Roma and I ended up getting a few things done.We decided to install all of the new ignition-related parts.
  1. Roma drew up a diagram of the distributor cap and which plug goes where.
  2. We pulled the old wires and trashed them. They were Mopar brand, and seemed to be in fair shape.
  3. We pulled the old distributor cap and rotor off. A bit of build-up was observed on the cap contact points. We kept the old cap and rotor, to be placed on the shelf "for emergencies". A new cap and rotor were installed.
  4. The old coil was pulled and shelved. Boy was this more of a chore than I thought that it would be. Roma's hands are smaller than mine and still struggled to get the mounting strap bolts loosened so that the coil would slide out after loosening the strap-tightening bolt. A new coil was installed, but we still need to tighten the bolts when we get more daylight (and when it isn't 32'F outside). It took us about 30 minutes to find a bolt that I dropped from my cold-stiffened fingers, and the bolt had somehow found its way between the oil pan and the crossmember.
  5. Roma pulled out the old plugs. I meant to take a picture of them, but I forgot.
  6. We did a compression test. From cyl#1 to cyl #6, we got 165, 165, 170, 170, 160, 145. I'm a bit concerned over cyl#6, but we'll let it go until we can adjust the valves. That new starter and battery seem to be going strong.
  7. The plug tubes were removed and the old tube gaskets were pulled and trashed. New gaskets were installed.
  8. New Champion double platinum #7322 plugs were installed, with a dab of anti-seize on the threads. I read in Doug Dutra's Chrysler Slant Six Engines Workbench book to remove the metal ring gasket on the plugs, but I left them on. This was the first time that I've heard of taking the rings off. Any other thoughts on the matter?
  9. New wires were installed with dielectric grease.
Next on our list:
  1. Pull the timing cover and check the timing gears and chain.
  2. Replace engine mounts.
  3. Clean the power steering pump and try to find what appears to be a significant leak.
  4. Roma wants to get a hammer and dolly to "fix" a few dents.
  5. The battery tray is swiss cheese. I bought some fiberglass-reinforced Bondo to see if we can salvage the tray by coating it with the Bondo.
What else should we be looking at in the early stages of this rebuild?
PostPosted: Mon Jan 11, 2021 12:15 pm
Welcome to the Forum and props to you for giving an old Slant a new life along with teaching Roma along the way!! :D :D
Pics work fine for me.
I remove the gaskets from plugs in the drool tube heads.
PostPosted: Mon Jan 11, 2021 8:25 pm
Congrats, Roma! Same color as our first Valient Custom.
(Don't forget to gently back-flush the heater core while you are working the coolant system. )
PostPosted: Mon Jan 18, 2021 9:44 am
I want to give a HUGE thank you to @matv91 for helping me with the Holley 1945 carb. It appears that I was missing more parts than I expected and he helped me ID many of them, and even sent some to me.
Here are some pics of the carb, for those that are interested:
PostPosted: Mon Jan 18, 2021 10:27 am
Getting back on track . . .
When the seller said that he thought that the timing had skipped a tooth, I was worried. But, for those of you that like to read the last chapter of a book first, we ended up finding out that the timing (at least the crank & cam) looked great.
In anticipation for using a puller to remove the pulleys and harmonic balancer, the radiator needed to come out. Roma was a champ and did that all herself while I complained about the cold, the wind, and the darkness.
And she was rewarded with this:
We called it quits for the night. The next day, I removed the balancer and Roma removed the timing cover.
The chain appeared to be in good shape. I didn't see any broken teeth or abnormal wear on the gears. The slack on the chain was just under 1/4" going perpendicular to the direction of travel, and when I turned the cam gear while holding the crank gear, the chain would only move around 3/32" as the slack was shifted from one side to the other.
A new timing cover gasket was ordered. I also ordered a valve cover gasket, since we will be checking the valvetrain next. I don't think that my timing gears are adjustable, and I'm not sure how to degree in the cam with the head still attached, so I think we'll skip this step (unless anyone thinks otherwise?). We also ordered a new harmonic balancer, since this one was showing a good amount of rot. Finally, we also purchased a carb repair kit, knowing that the carb will be coming off soon, for inspection if nothing else.
While she was pulling the cover off, I wanted to investigate the A/C system. I purchased some retrofit adapters and was planning to pull a vacuum to see if we had any leaks. I had already measured the old connectors, which were 7/16. However, the adapters that I got were mislabeled:
The low-side connectors are the right size, (ignore my sloppy technique), with a female diameter of roughly 0.41":
The high-side connectors were a bit of a different story:
0.35", which is 3/8, and too small to fit onto a 7/16 connector, obviously. The 3/8 connector part number should be 5811352, but the bag of parts was labeled as 5811351.
PostPosted: Mon Jan 18, 2021 11:18 am
Looks like a fun time so far.
I bet you'll get everything sorted and running soon in time for the nice weather to come around.
Yes the stock type timing set you've got there is not adjustable without modifications.
the Cam center line can bet determined with the head on the car.. You just need a Degree wheel / pointer for the crank, a TDC Indicator or spark plug hole piston stop, and then a Dial indicator.
You will need to take the Valve cover off to expose the #1 Intake valve spring retainer or rocker arm.
Best of Luck!
PostPosted: Mon Feb 08, 2021 8:02 am
No photos for this update. Sorry. My fingers were too cold to operate my phone without dropping it, and I did manage to drop a socket and wrench onto Roma while I was working on the top of the car and she was underneath it. Stupid freezing weather. (Roma was not injured, in case you were wondering).
Roma really wanted to paint the motor, and I told her that the best time to do that was while the engine was pulled. We hadn't planned on doing that, but I figured that we still have 2 years until her 16th birthday, so we have some time. We also debated how much work, repair, end cleaning we should do while the engine was out. She had already removed the valve cover, and the valve train was a filthy mess. Lots of black crud covered the rocker arm assembly. It would need to be removed so that we could clean it all up correctly. With the state of the valvetrain, we figured that the rest of the oiled systems were similarly in poor shape. We decided that we would do our best to clean the oil galleys and do the coolant passages at the same time (considering all of the lime found in the radiator). We would pull the head and check it over for valve seat wear, etc. We would drop the oil pan and remove the crank, which would get new bearings. The pistons would get new rings and rod bearings. The cam would get looked over, and we may go back with a bigger cam. She's not a gearhead trying to make more power, but I figure that as long as we are in there . . . . .. And once everything was buttoned back up, she would primer and paint the block, head, and other assorted visible items. So we got moving on pulling the engine.
With the correct retro fittings for the AC, I tried to pull a vacuum and that failed significantly. I will need to get an adapter and use my air compressor to find the leak. But until then, Roma removed the compressor and the lines from the firewall plus the TXV. I pulled the receiver drier and found that one of the connectors was only finger tight and the internal o-ring was pinched. This might be my source of the leak?? The condenser will come out soon.
Roma removed the carb and vacuum amplifier from the top of the engine.
I loosened the motor mount bolts, which were disintegrating.
We tried to take off the exhaust line from the manifold, but the bolts were rusted. 2 days of penetrating oil and a MAPP torch did nothing to convince the bolts to exit. An significant application of leverage finally caused the bolt heads to snap off and the exhaust line dropped away.
Roma removed the power steering pump and alternator. The PS pump and steering box are coated with lots of grime and oil. What little fluid that came out of the pump was more like motor oil than any type of PS fluid that I've ever seen. It was dark brown to black. We'll need to disassemble and service the PS pump as some point before we put it back in.
I disconnected the various wiring for the oil pressure sensor, coil, alternator, and AC pressure switch. I ended up breaking the wiring for the oil pressure sensor, so that will need to be fixed eventually, too.
Roma removed the shield on the bottom of the bell housing and, with some of my help, removed the flex-plate-to-torque-converter bolts. The TQ was also drained.
I should probably note that the analysis reports for the engine oil and ATF came back from Blackstone.
The engine shows lots of wear. Iron (and chrome) accumulates as the engine wears without changing the oil. I'm more concerned about the lead and tin (babbitt), which is most likely from the bottom end bearings (crank and rod bearings). That's quite a bit of lead and tin. I'm glad we decided to pull the engine and replace the bearings.
The ATF analysis shows similar indications of wear and (ab)use. The fluid was well past the time for it to be changed.
Roma and I then began to remove the engine-to-trans bolts, leaving one in place for now until we can get a few hours of dedicated time to hook up the hoist and pull out the engine.
Next steps:
  1. Pull engine
  2. Disassemble/clean/rebuild engine
  3. Rebuild carb
  4. Rebuild power steering pump
  5. Examine/rebuild AC compressor, repair AC system
  6. Transmission
  7. Driveline/axles
  8. Brakes
  9. Suspension
  10. Body work
  11. Exhaust
  12. Electrical
  13. Interior
PostPosted: Thu Apr 15, 2021 12:43 am
Great progress getting that Valiant back to its glory! Wayt to go
PostPosted: Thu Apr 15, 2021 4:50 am
Yes, very cool project indeed! Some great learning for Roma!!
PostPosted: Mon Oct 25, 2021 10:50 am
It's been a few months and several honey-do projects since our last update, but Roma and I finally got around to pulling the engine and beginning the disassembly. Note to future self: Do not try to hoist the engine on a sloped driveway. Pushing the engine uphill into the garage was not fun at all.
Roma had removed several accessories by the time I remembered to take some photos. Motor mounts, fuel pump, oil pump, distributor, and various brackets were all removed. The cam came out next.
The rocker arm assembly was then removed, followed by the head itself.
The piston tops and combustion chambers were all covered in carbon.
One of the manifold studs looked like it had been cross-threaded, so I will need to chase it with a tap and possibly heli-coil it. The studs themselves were fairly well rusted. Does anyone know of a source for stainless studs?
We flipped the engine over and pulled the oil pan off. There was an unhealthy amount of sludge in the pan, as I suspected. A few squirts of gasoline and some paper towels produced a clean oil pan. Likewise, a few sprays of gasoline on the rocker arm assembly started to dissolve the sludge on all of those bits.
I requested a regrind quote from Oregon Cam, requesting a price for the RV15 specs that I've seen recommended here. They quickly sent me back a quote for either the 2106r or 819i/818e. I think I'll go for the 819i/818e.
To do:
  1. Purchase replacement manifold studs (stainless?)
  2. Regrind cam and lifters
  3. Purchase a set of rings and bearings
  4. Purchase gasket set
  5. Take apart bottom end
  6. De-sludge oil passages and block
  7. Flush coolant passages
PostPosted: Mon Oct 25, 2021 12:38 pm
Looks like great progress! Glad you both are enjoying this and learning together. Best of luck with the rebuild and improvements!
Dorman (parts store) has good studs to use. Mcmaster.com is another good source. Stainless is probably not a good idea because of the weaker metal properties. I have never used stainless, but I suppose you could try it.
