It is currently Thu Nov 19, 2026 7:11 pm
PostPosted: Wed Jan 27, 2021 11:39 am
What are the best vehicles to find cast crank engines in...?
In ALL of the pile of Slant 6 engines I have accumulated over the years I have yet to come across a cast crank engine (determined by the web behind the water pump).
I’ve lost count of how many Slants I have. Almost all are forged crank 225s. I have just one 198 and still no 170s... :?
PostPosted: Wed Jan 27, 2021 11:44 am
My garage has one from 1981 that you can have for free....!
PostPosted: Wed Jan 27, 2021 11:55 am
Everything 1977 and later is cast crank and all are 225 ci. I don't know what you mean by the web behind the water pump. The forged crank blocks have a prominent casting number on the left side of the block which is absent on cast crank engines.
PostPosted: Wed Jan 27, 2021 12:02 pm
Late f Bodies - All trucks 1978-1978
The trucks are very common on the typical used vehicle places.
PostPosted: Wed Jan 27, 2021 12:10 pm
As has been said, any slant 77-up is a cast crank. Lots of them in trucks and vans from the 80s.
Give this guy a call:
https://lexington.craigslist.org/pts/d/ ... 29441.html
PostPosted: Wed Jan 27, 2021 12:14 pm
The cast crank went through a weight reduction program during its life span. The early 1977 cast cranks have bob wrights nearly as large as a forged crank. The last year, 1987 cast crank is really spindly by comparison. This is based upon tearing down a ‘78 cast crank motor, an ‘83 cast crank motor and an ‘87 cast crank motor.
PostPosted: Wed Jan 27, 2021 12:29 pm
Car Model: 1975 Dodge D100
This detail is described in the article Slant Six Blocks by Doc.
https://www.slantsix.org/articles/dutra ... blocks.htm
PostPosted: Wed Jan 27, 2021 12:37 pm
I think cast cranks have been around way longer than 1978. It says right in the Bible, "Let he among us who is without sin cast the first crank"
yup they were phased in sometime within 1976 model year. a 76 engine could have come either way. Look at the stamped number on the block by the #1 cylinder behind the alternator. It will have an "E" in the line of numbers there if a cast crank.
That said, there will be a "running" cast crank slant, coming out of my '85 D150 later in the spring. I can go out in the garage right now, hook up the "-" to the battery and fire it right up. just under 100K original miles.
OOPS I messed up. I meant to hit "Quote" and hit "EDIT" instead. I wasnt wanting to change the post, just quote it then add to it in another reply box. Sorry about that. Brain fart.
(Volaredon)
PostPosted: Wed Jan 27, 2021 4:50 pm
I don't think that's accurate. Here's a picture of my cast crank block and the water pump pocket reinforcement is of the same tapered style as the forged crank engine Doc pictured. Sorry about the picture quality, but I'm still cleaning the block.
PostPosted: Wed Jan 27, 2021 6:02 pm
After reading that same description I used to wonder about that too. It helped me to think up and down thickness instead of side to side width.
The web on a forged crank block gets thicker and wider on the block end. The same web on a cast crank block gets wider but stays the same thickness.
PostPosted: Wed Jan 27, 2021 7:20 pm
Sure. I still think the casting number is easier to see.
PostPosted: Thu Jan 28, 2021 4:35 am
:oops: :oops:
Well then.... I s'pose I prolly do have a few then.... :roll:
All these years I read that article to mean the thickness of the "gusset" as actually the width. Now that it's been pointed out I can see the more subtle increase in thickness of the rib...
Well,... At least I know my Poser status is secure still... :lol:
PostPosted: Thu Jan 28, 2021 7:28 am
Poser
:roll: :roll: :roll:
PostPosted: Thu Jan 28, 2021 9:48 am
Well well well,.... If it ain't Cookie showin' up at the first mention of the word Poser... :lol:
Good ta see ya still around Cookie. :wink:
PostPosted: Thu Jan 28, 2021 9:52 am
I just swung by the garage to meet some friends for some parts swappin'.....
Yep... several of them engines layin' back there got the thinner web thingy what don't get no thicker (not wider)... :roll: :lol: :oops:
I just gave one of 'em away. Hopefully it'll wind up in Dennis' old Duster... or somethin' else cool...
