It is currently Tue Sep 22, 2026 7:56 am
Post new topic  Reply to topic  [ 158 posts ]  Go to page Previous 17 8 9 10 11 Next
PostPosted: Sat Apr 06, 2019 10:29 pm
Car Model: 1964 Valiant
Any updates on this effort ?
PostPosted: Sun Apr 07, 2019 10:56 pm
Yes, updates please!
~THOR~
PostPosted: Thu Jun 27, 2019 10:31 pm
I'm moving my car into some space at my machine shop this weekend to start working on getting the transmission mounted. I have sub frame connectors to weld in that I'm going to use to mount the transmission crossmember to. Then I can button up the tunnel. I'll post some pictures once I make a little more progress.
PostPosted: Fri Jun 28, 2019 4:51 am
Good to hear! Keep at it.
PostPosted: Fri Jun 28, 2019 1:39 pm
Cool deal!! Still have My eye on this, whenever You have the set-up worked out, let Us know when You can start on Our pieces!!! :D :D
PostPosted: Tue Jul 02, 2019 4:54 am
Cooi. Happy to send $$ for parts/materials whenever...
PostPosted: Mon May 04, 2020 8:05 am
OK, ....it's that time, any updates Casey??? Still interested......hope all is well with You & Your's........
& that goes for all Members as well.......
PostPosted: Tue Feb 02, 2021 12:36 pm
OK & alright, it's a new Year, & My obligation to give this thread a bump! If You're out there Casey, hope You & that young family of Yours are doing well! I am still interested in this setup, let Us know what's goin' on, peace Brother!
PostPosted: Tue Feb 02, 2021 3:55 pm
casedawg hasn't logged on since Fri Jun 28, 2019 12:33 am
PostPosted: Tue Feb 02, 2021 4:44 pm
Ive seen some blurbs online different places using (yeah I know a 5 speeed, not 6) a W58 and adapting it to different engines, it is an "AISIN" brand trans largely used by Toyota.... If I could get past "a Toyota 'ANYTHING' in my Dodge"? I'd think of trying that idea.... I had tripped across that thought when scoping out my Volare build (which is stuck in neutral)
My "hangup" is that I wouldn't take a Toyota anything as a daily driver even if it were free........ not sure I knowingly want parts of one in my vehicles, either
I thought about it again last fall as there was a W58 trans on CL then.......
PostPosted: Tue Feb 02, 2021 7:01 pm
Seems like there was a place in Australia (Castlemain Rod Shop?) that made an adapter plate to put a W58 behind a Slant. I would have no trouble with Toyota parts in my car if they are decently easy to source/repair and reliable (pretty much a given with Toyotas).
PostPosted: Wed Feb 03, 2021 7:36 am
I would be cool with 'yota parts in my car.
I have ford parts in there now - which are not really ford part they are borg warner / tremec.
Does the 6 speed have a gear (5th) between the say 0.61:1(6th) and 1:1 (4th)
PostPosted: Wed Feb 03, 2021 7:39 am
Looks Like
the Aussy Rod shop provides adaptors for the Aussie "hemi" 6
https://www.rodshop.com.au/bellhousings
PostPosted: Mon Feb 08, 2021 7:04 am
No, 5th is1:1 ,& only 6th is an OD. This is what l've always wanted, a low propshaft speed & well spaced gears deep enough to not need a high rear ratio. I plan on using the 8.8 IRS I've got with the 3.27's in it. The one thing l hate about steep gears is the extra driveline vibes. Early in this thread Casey listed the ratios.
PostPosted: Mon Feb 08, 2021 7:28 am
No, there is no 1:1 ,& only 6th is an OD. This is what l've always wanted, a low propshaft speed & well spaced gears deep enough to not need a high rear ratio. I plan on using the 8.8 IRS I've got with the 3.21's in it. The one thing l hate about steep gears is the extra driveline vibes. Early in this thread Casey listed the ratios.
Thanks I will have to look at those ratios. Must be sweet close ratios I imagine.
