It is currently Fri Jun 19, 2026 9:03 pm
 Post subject: 318 help
PostPosted: Mon Jun 28, 2004 7:34 pm
I have decided to swap a 318 into my Uncle's 82 D-150 which currently has a 225. A good friend of mine wanted to get rid of this motor because he got tired of it sitting in his yard. I told him I would take it since it only needs a basic overhaul and its free. Here is what I got. It came out of a 1980 Diplomat and it has a set of 360 heads and a 4-barrel intake. No water appears to have gotten into the motor and it was full of oil until it turned over in the back of my truck. I think I will do a close to stock rebuild because the last engine I overhauled was several years ago and that was 3 horse Briggs & Stratton. I found a set of pistons with 9.5 compression ratio. Is this too high a compression, and will I have any detonation issues? Also, will I have to run premium grade fuel through it?
I think I will use one of the Comp Cams truck power camshafts in it, because I would like to have lots of low-end torque since this truck is going to be doing a lot of towing. Any advice would be much appreciated. :D
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Re: 318 help
PostPosted: Mon Jun 28, 2004 8:25 pm
...should address those questions to www.318.org....
D/W
If it ain't broke, fix it!
PostPosted: Tue Jun 29, 2004 1:24 am
Car Model: 1966 2D Dart
Dennis,
do not be so disapproving! I quess he is greedy for his uncles slant.
Maybe the next question is from where to get the mounts to F-150/slant conversion.
PostPosted: Tue Jun 29, 2004 5:19 am
I'm not disapproving - I love the LA and the big block, for that matter, I have several of "everything" myself... Just seemed like the wrong forum, and I was just teasing old Jeb, anyway... :twisted: :D
D/W
PostPosted: Fri Jul 09, 2004 5:32 pm
You will be doing good to have 8.0:1 compression with the 360 heads as they are 8-9 ccs bigger than the 318s so 87 should be fine and about 34-35 degrees of timing total, if it is the heart shaped chambers (not knowing) you can only run 30 degrees of timing total due to combustion chamber shape and the efficiency.
 Post subject: ?
PostPosted: Sun Jul 11, 2004 9:04 am
"it was full of oil until it turned over in the back of my truck."
Thanks for the chuckle! Been there, done that(more than once, I'am ashamed to admit). It is reassuring to know I am not the only bonehead out there.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Sun Jul 11, 2004 11:31 am
Car Model: 1967 Dodge Dart GT
:lol: just did that myself while hauling the old motor to the backyard...
PostPosted: Mon Jul 12, 2004 5:52 pm
At least the oil will stop the rust problem that I am having in the bed. Even if everything slides around now when I take a curve or hit the gas.
82 D150-225/727
