It is currently Tue Nov 17, 2026 2:07 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
 Post subject: Dual Dutra Duals
PostPosted: Mon Feb 22, 2021 11:37 am
Is there any difference between Manifolds if you plan on running Dual Dutra Duals on the Front and rear?
Are the castings the same?
- I want to say they are but I want to be sure as I have one and need to locate another one to make a set.
 Post subject: Re: Dual Dutra Duals
PostPosted: Mon Feb 22, 2021 12:40 pm
No I don't think they're the same
The dumps are different between them
PostPosted: Mon Feb 22, 2021 1:14 pm
They may be different now since AussieSpeed assumed the production of those parts, as I had read that they made a change to improve the clearance of the flange to the starter. I have a set on the 83 D150 that I bought new back in 2010, and then anyway the front and rear were the same part. Which probably explains why the flange is close even with a mini starter.
PostPosted: Mon Feb 22, 2021 1:16 pm
Okay, That's What I thought.
I don't have any aussiespeed parts Just Doug's Castings.
PostPosted: Mon Feb 22, 2021 3:52 pm
maybe its the Aussie one I'm thinking of then? Hyper-Pak had a set of 1 of each for sale here recently with pix. the ad is still there, even though the pieces are marked sold.
It hasn't "fallen off" the bottom of the list yet/ Oat least it was still there yesterday)
PostPosted: Mon Feb 22, 2021 4:36 pm
Yes they are different. ( This is a new pair bought in 2021). Rear one aims slightly forward. I am putting them on Ryan's 65 Valiant right now. They do not easily fit he 170 engine. Well that is not true. They fit on the engine fine, but the starter is the problem. The 1" shorter stroke places the manifold down where the mini starter hits, and the planetary (super mini) hits the solenoid. Ryan ordered a Robbmc starter that can have the solenoid rotate to any position. Hopefully it can rotate the solenoid out of the way. I'll let you know if it works.
PostPosted: Mon Feb 22, 2021 4:39 pm
Don brings up a good point, the most front and rear attachment points for the slant exhaust is a stud, so perhaps for even on the older Dutra's the manifolds are unique. Maybe just the machining.
I have not had the hood up on the 83D150 in months,( it sits out the winter ) I'll go in the garage tomorrow and take a look.
 Post subject: D
PostPosted: Mon Feb 22, 2021 5:17 pm
D
PostPosted: Mon Feb 22, 2021 5:20 pm
Yes they are different. Rear one aims slightly forward. I am putting them on Ryan's 65 Valiant right now. They do not easily fit he 170 engine. Well that is not true. They fit on the engine fine, but the starter is the problem. The 1" shorter stroke places the manifold down where the mini starter hits, and the planetary (super mini) hits the solenoid. Ryan ordered a Robbmc starter that can have the solenoid rotate to any position. Hopefully it can rotate the solenoid out of the way. I'll let you know if it works.
Good Stuff Rick, Thanks!
PostPosted: Mon Feb 22, 2021 5:23 pm
My Dutra rear manifold was drilled for the stud at the rear of the manifold. And the outlet turned slightly forward. I don't know why you could not drill a hole to use it forward if needed.
PostPosted: Mon Feb 22, 2021 5:25 pm
Sorry, slightly aft.
PostPosted: Tue Feb 23, 2021 4:47 am
When I bought a pair from Doug in about 2000 for the turbo Dart, they were identical except for the hole drilled for the ends of head. He had several castings with different outlet pads, so if you mix and match they would be different front and rear. They were intended to be same front and rear for each casting he made.
PostPosted: Thu Feb 25, 2021 3:32 pm
as mentioned photos of a rear Dutra Exhaust,, these are vintage 2010 parts, way before AussieSpeed took over production.
the front and rear castings are the exact same parts, machining changes to a drilled pilot hole and spot face change allow the casting to fit in either position. The issue is the rear manifold flange is tilted to allow minimal clearance to the starter. That situation is workable with a mini starter on a 225.
I believe that AussieSpeed modified the pattern to produce a rear manifold that improves the clearance to the mini starter.
File comment: clearance of an original / pre AussieSpeed Dutra to a mini starter.
File comment: back when it was all new
PostPosted: Sat Feb 27, 2021 9:48 am
In any combination of these manifolds, is it possible to keep an O.E. style starter?
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Sat Feb 27, 2021 10:56 am
Dyno Dave, I think the problems arise using them on a 170, low deck slant six.
On a 225 I think there is enough clearance.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 2 guests
