It is currently Mon Nov 09, 2026 2:11 am
 Post subject: Distribution block
PostPosted: Fri Mar 12, 2021 8:18 pm
Car Model: 78’ dodge D100 slant six
I need a good block. I also need to know where and how to hook it up. Does it go inline with battery cable or come off the smaller line? Thanks
 Post subject: Re: Distribution block
PostPosted: Sun Mar 14, 2021 7:19 pm
what are you looking to do? rewire the whole truck thru this or just add capacity for accessories or what?
PostPosted: Wed Mar 17, 2021 1:12 am
Add for accessories. That’s all I want
PostPosted: Mon Aug 30, 2021 12:31 am
First you must consider if your accessories need to be powered all the time, or only when the key is ON, or if when key is ON or ACC. If "all the time", you can run a fused wire directly from battery. For ACC/ON, I'd power the distribution through a fused relay, and power the relay with a source that meets the ON/ACC requirement. When the relay is powered, your accessories have power.
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Fri Sep 03, 2021 11:11 am
They will all be on a relay and only powered on with key.
Users browsing this forum: Amazon [Bot] and 2 guests
