It is currently Wed Aug 12, 2026 11:24 pm
Post new topic  Reply to topic  [ 616 posts ]  Go to page Previous 120 21 22 23 2442 Next
PostPosted: Mon Mar 29, 2021 12:35 pm
rob, What year engine (late or early crank), and what trans, (late or early) cable or linkage type shifter?
PostPosted: Tue Mar 30, 2021 3:34 am
The engine/trans in it is a later 225/904. We put a Hurst Promatic cable shifter in it.
PostPosted: Tue Mar 30, 2021 4:10 am
Ok.thanks. Saw what happened to EVR at NOLA. Figured I would look and see what I have for spare parts. Such as trns, converter, flexplate, etc. Probably wouldn't bring them down, unless you think I should, but I'm close enough do do a quick parts run if necessary.
PostPosted: Tue Mar 30, 2021 7:22 am
That's awesome Charlie! I am considering throwing a spare engine/trans on the trailer... I have one out of an 85 D100. I saw a video of it running... engine and trans are separated and no converter, but should be decent spares if needed...
PostPosted: Tue Mar 30, 2021 2:55 pm
Just let me know what to bring. probably have enough spare parts. just trying to get organised ahead of time. I thimk you saidd it had a 7 1/4 rear. What ratio, and bolt pattern?
PostPosted: Wed Mar 31, 2021 5:24 am
3.55 Sure Grip with 5x4.5 LBP.
Joe left the 2.76 tag on there to fool the judges... :mrgreen:
PostPosted: Wed Mar 31, 2021 11:24 am
I would have concerns about a 7 1/4 on a road course. I have aa 3.91 SG I have been building. Still need to set the gear pattern. I'll see if I can get bthe time to get it done, in time for spare. That is the only BBP limited slip rear I have. Most of my rears are either SPB, open or spool.
PostPosted: Wed Mar 31, 2021 1:14 pm
We ran a 7-1/4" open diff for a couple races with no problem, but I suspect the Toadracer will be putting down faster lap times than we did back then...
Escape Velocity Racing
PostPosted: Wed Mar 31, 2021 2:07 pm
Not at Sebring. It’s just a stock motor that’s been sitting for 8-9 years.
PostPosted: Thu Apr 01, 2021 9:07 am
Charlie, any chance you can scour your 904 collection for some V8 clutch drums before Sebring? I'm still looking for a set to build up a proper race transmission.
PostPosted: Thu Apr 01, 2021 2:04 pm
I'll try, in the next couple of days Wht trns are you runnin?, Approx year
PostPosted: Thu Apr 01, 2021 9:30 pm
1964 cable-shift with push-buttons on the dash. Thanks!
PostPosted: Fri Apr 02, 2021 5:27 am
Are you still using the early small input shaft, in the trans?
PostPosted: Fri Apr 02, 2021 1:15 pm
Yes, everything's original to 1964. As far as I know, the V8 drums are the only thing I'll be able to easily swap in.
PostPosted: Fri Apr 02, 2021 4:47 pm
We're getting closer on the ToadRacer logo...
