It is currently Sat Nov 14, 2026 1:06 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 06, 2021 9:59 am
It's only problematic for ignition if you don't do your research and don't get the bugs worked out.
It makes way more Sense to control the Ignition and fuel if you can. Lots more non linear flexibility and tunability vs Carb and distributor. The hyperpak intake will respond well to EFI, I have a Carb on my Hyperpak for nostalgia purposes.
PostPosted: Tue Apr 06, 2021 10:01 am
Subscribed
--> The Diesel Corvette <--
PostPosted: Tue Apr 06, 2021 12:16 pm
Ignition power is really not a big deal unless boosting substantially. The kicker is getting timing curves down and avoiding crossfiring or misfiring due to noise in the system or rotors/etc out of phase with the ign trigger.
PostPosted: Tue Apr 06, 2021 1:11 pm
Car Model: 1966 2D Dart
Spark quality makes sense (in my application) where the fuel is 85% ethanol. It matters more when the weather is below freezing point and the fuel is still mostly ethanol. Spark can not easily be overpowered. I have had one exception for that. A russian car called Moskovitz was generating troubles with non-russian spark plugs. At that condition the spark easily runaway to ground before plug gap!
PostPosted: Tue Apr 06, 2021 2:29 pm
Thanks for all the input guys! Much appreciated. I starting to gain confidence...
Another question. Am I better off going with the latest MS3? I have and older MS2 3.75 that as gifted to me.
These ones go to eleven...
PostPosted: Wed Apr 07, 2021 5:15 am
There is likely better support for MS3 and more tunability/flexibility. Greg might give you a direct opinion on that. I decided to skip MS2 myself, but I do not have MS3 running yet.
PostPosted: Wed Apr 07, 2021 6:44 am
Car Model: 1966 Dodge Dart
It's pretty easy to upgrade an MS2 to an MS3 by swapping the daughter card. The main benefits are sequential injection (along with individual cylinder tuning) and more I/O.
Matt Cramer
PostPosted: Wed Apr 07, 2021 7:37 am
Good to know Matt!
PostPosted: Wed Apr 07, 2021 7:58 am
Yes, thank you Matt! And thanks for the Fuel injection book!
This what I have. http://www.megamanual.com/357/intro.htm
The MS3 daughter card will plug into it? If yes I will order.
I sometimes have the skill of overlooking the obvious...
Cheers,
Barnaby
PostPosted: Wed Apr 07, 2021 1:37 pm
Correct - you'd also need the taller MS3 case, and the MS3X expansion board if you are using the MS3's extra I/O and not just the extra settings.
Matt Cramer
PostPosted: Wed Apr 07, 2021 2:26 pm
Rad!
Thanks you MadScientistMatt!
