It is currently Thu May 07, 2026 6:15 am
PostPosted: Thu Jul 15, 2004 7:15 am
I am interested in upgrading my 12 volt regulator (ciol/points type) to a solid state unit. I understand there is one available that looks like the original regulator. Where can I find this? Is this the best way to go? Is there a generic regulator that is cheaper/better? Thanks.
PostPosted: Thu Jul 15, 2004 11:02 am
This solid-state retrofit is a great regulator if you want to keep your original alt, wiring, etc.
The ones I have bought are Borg-Warner, I'm sorry, I don't have the part #... Check with your local real parts store (if you have one) that can get B/W stuff... May be others available, too. Maybe try NAPA...
D/W
If it ain't broke, fix it!
PostPosted: Fri Jul 16, 2004 2:03 pm
The JC Whitney pn for the regulator I bought is in this previous discussion.
It was fairly close to stock appearance and survived my son's various
radios amps and boomers (read ear drum breakers).
http://www.slantsix.org/forum/viewtopic ... ator#27231
PostPosted: Sun Jul 18, 2004 8:50 am
Thanks for your help, I'll check both sources.
 Post subject: Follow Up
PostPosted: Sun Jul 18, 2004 6:07 pm
Turns out the last one (transistorized retrofit) I got for my '69 Newport was a "Standard"... I still have the box: Part No:
VR101T
There are some crosses on the box - not sure if they are for the transistorized unit or not:
MM (Motor Mite): CH524
BW: R280
NIE: AL169
Wells: VR706
You should be able to obtain one without difficulty.
D/W
PostPosted: Wed Aug 11, 2004 12:20 pm
Years ago (more than 10), I bought a new regulator for my '61 Belvedere (Chrysler alternator); I believe it was a Std. Ign. unit...looked exactly like my old points-type reg.
Last year, I bought a new Std. Ign. regulator for my '64 Valiant; I'm ashamed to put it on my firewall: it is this hideous blocky plastic thing...
I think Filko also made solid-state look-alike regs...
Also check out KEM....
De Soto Frank
PostPosted: Sat Sep 11, 2004 6:37 am
Can anyone confirm that a VR706 is electronic guts with the old style case?
PostPosted: Wed Sep 15, 2004 9:51 am
Yes! The mopar performance regulator died recently in my Barracuda and I picked up a Wells VR706 to replace it. There was even a little sheet in the box explaining that the difference in appreance was because it was solid state.
This regulator is not as thick as a mechanical one and did not have a painted case. If you are looking for originality this regulator is close but is also obvious that it's not original. The case is only 1/2" thick verse the 1"+ of a mechanical one.
Dave Clement
68 Barracuda (Hot-Rod \6)
http://mysite.verizon.net/vze4pgxf/
PostPosted: Wed Sep 15, 2004 4:07 pm
The parts database shows Ampco and Wells, both VR706. The last one I bought was the Wells with a chrome case.
Chuck Rivers, Webmaster
Image Image Image Image
