It is currently Sun Nov 15, 2026 1:45 pm
PostPosted: Sat Apr 10, 2021 7:51 pm
Car Model: Duster
I am new to the slant 6, learning fast. My car is a 1971 Duster, but I think my engine came out of a early 80s Pickup. Pretty sure I have what is referred to is the "peanut" head. It does have the air injection port in the back (plugged). I am in the process of getting the engine to run reliably. doing all the usual, carb, ignition, timing. Figure I would replace the valve cover gasket when I go to adjust the valve lash. I am not sure which gasket will work for mine. This engine definingly has an oil leak somewhere as it had a nice thick coat of grime over it.
PostPosted: Sat Apr 10, 2021 10:56 pm
Welcome to the club. That's the '81 and newer hydraulic lifter engine so there's no valve lash adjustment to be done.
PostPosted: Sun Apr 11, 2021 5:49 am
could be... valve adjustment or not, who knows what hodge podge of parts someone put together.... hell know when he gets that cover off for sure!!!
PostPosted: Sun Apr 11, 2021 5:51 am
If you ask for a 1981 Dodge pickup or diplomat, you'll get the right valve cover gasket. Application range is 1981-1987 trucks and cars with Slant 6 (225, 3.7L) engine.
PostPosted: Sun Apr 11, 2021 8:32 am
This should get you setup..
https://www.rockauto.com/en/parts/fel-p ... sket,10710
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 10 guests
