It is currently Sat Nov 21, 2026 11:01 am
 Post subject: Block identification
PostPosted: Wed May 12, 2021 9:50 am
Car Model: 1965 valiant signet convertible Al1p
There isn’t much I was thinking some of the numbers are missing ,may got taken off when or someone forgot?what there is AL-P-(1?)*****C
 Post subject: Re: Block identification
PostPosted: Wed May 12, 2021 12:44 pm
Your avatar says "'65 Valiant Signet AL1-P", which is a Canadian model designation. That's a Dart-shaped Valiant, the 111"-wheelbase car that's like a U.S. Dart GT, but with Valiant badging and some mechanical differences mostly in the electrical system.
Likewise, your engine stamping is Canadian. I think if you look closer you might see it says AL-HP.
A: 1965 model
L: Valiant (111" wheelbase)
HP: High-performance engine option (225 instead of 170)
The rest of it will be date/serial stuff.
PostPosted: Thu May 13, 2021 7:56 pm
That makes sense beyond that, if it is a HP motor it would or could have double roller timing chain? Did it use same cover?Is there a difference visually between the heave duty oil pump? What about compression? Could the numbers be missing from being decked? So many ? Owe you ....thanks high octane all its life.
PostPosted: Thu May 13, 2021 9:33 pm
Glad to help. In this case "HP" just means a 225 instead of the standard-equipment 170. It doesn't mean a special heavy-duty 225.
Users browsing this forum: Bing [Bot] and 5 guests
