It is currently Tue Nov 17, 2026 10:04 am
 Post subject: Clutch Question
PostPosted: Mon May 17, 2021 1:38 pm
Car Model: D150
Clutch kit {MU15251} installed two years back, 1983 D150, maybe 2500 miles on it. Would a failing pressure plate cause the adjustment
to go out of wack? I know all of these aftermarket parts are junk, but could something like this happen?
 Post subject: Re: Clutch Question
PostPosted: Mon May 17, 2021 2:38 pm
Tob could be plastic or garbage..
What brand / vendor is this from?
Mods... can this be moved to the tranmission/rearend forum?
PostPosted: Mon May 17, 2021 3:30 pm
Yes it could
PostPosted: Mon May 17, 2021 4:26 pm
Done
PostPosted: Mon May 17, 2021 5:11 pm
In the 83 D150 I had:
a clutch kit from Brute Force that failed in less than two years of service due to the TOB plastic housing de laminating.
a clutch kit from NAPA fail in just over two years due to improper staking if the adjustment bolts and the clutch plate levers getting out of adjustment.
so yes I would agree that stock replacement 10 inch clutch kits are junk and need to be looked over closely.
The most recent clutch kit that I put in, from AMS Automotive-RockAuto has a metal TOB housing and I welded over top of the PP adjustment bolt staking.
PostPosted: Tue May 18, 2021 4:08 am
I t took me 3 clutches about 5000 miles apart to get a good one for my 93 318 Dakota that I converted to a 5 speed from auto.
Both times the plastic throw out bearing failed.
Perfection brand clutches certainly aren't.
The 3rd clutch was. LuK brand and it was great for 72k miles and would have been file for longer if I hadn't totalled it. I'd certainly buy another LuK brand.
PostPosted: Tue May 18, 2021 7:03 pm
Car Model: D150
Thank you, and I'm sorry for posting in the wrong section.
It is official, the pressure plate crapped out.
I just love doing things twice.
PostPosted: Wed May 19, 2021 4:19 am
Mods... can this be moved to the transmission/rearend forum?
Done
Thanks Charrlie.. getting it done on the road course and on the Moddin' here. Arrericated :D
PostPosted: Wed May 19, 2021 4:22 am
Sorry to hear that.
If you can find a local independent clutch rebuilder that could be helpful.
also if the disc is in in good shape I would venture getting a new pressure plate - or getting yours rebuilt properly.. I sent a 9" skookum Disc and PP assembly to Falcon Clutch in NY. I called and spoke to the tech on the phone and told them exactly what I wanted on my rebuild with spring pressures facing materials etc and I think I got the part back in something like 3 weeks. They also migh be able to just build one for you.
PostPosted: Wed May 19, 2021 4:50 am
I bought a "Perfection" clutch about a year ago. Haven't installed it yet. All the other brands I bought had a smaller disc, then the pressure plate. That was the reason I chose the Perfection brand. It did come with a plastic TO bearing, When I called Perfection, and complained, and related instances of failures, they sent me a metal TO bearing no charge.
PostPosted: Wed May 19, 2021 7:11 am
The AMS clutch kit that I installed recently had the correct 10 inch disk.
PostPosted: Tue Jun 22, 2021 2:19 pm
Car Model: D150
This was the issue.
PostPosted: Wed Jun 23, 2021 11:19 am
I had a similar problem..
Those can be fixed!
https://www.slantsix.org/forum/viewtopi ... A+body+bar
PostPosted: Wed Jun 23, 2021 5:10 pm
Car Model: D150
Brewer's Performance, Inc
10510State Route 571
Laura, OH 45337-8799
http://www.brewersperformance.com
They're nice people over there, had everything I needed. New torque lever with bushings.
And I found them by sending an email to a guy on eBay selling a peddle assembly.
Ya just never know.
PostPosted: Wed Jun 23, 2021 7:32 pm
I've cut the arms off and rewelded them to a "new" hunk of pipe before, to solve that problem.
