It is currently Tue Jun 16, 2026 1:49 am
PostPosted: Fri May 21, 2021 12:13 pm
Car Model: 1968 Barracuda - Fastback
Does anyone have a part number for a flexplate that uses 3/8" bolts for a 904?
I considered drilling mine to enlarge the hole, I don't think there's enough meat there to work safely.
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Sat May 22, 2021 4:35 am
they have 5/16" holes now.... 3/8 means only 1/32" "on each side" of the hole bigger.... I don't think that would be enough to make or break the strength of the flexplate.
PostPosted: Sat May 22, 2021 10:29 am
http://store.440source.com/Solid-Flexpl ... 00%2D1040/
This is a V-8 one so it will need one hole drilled. But they have all the bolt patterns and are extra thick. same as the SFI one without the sticker. $38.95. If you want a sticker it is $10 more. This is what I am running in my race car.
PostPosted: Sat May 22, 2021 1:36 pm
I used an sfi small block one with the larger holes in my Ruster Race car.
Redrill the one hole on the crank as Rick noted and you should be set for the next million milea or 10,000 Dragstrip passes.
PostPosted: Sun May 23, 2021 1:42 am
Car Model: 1966 2D Dart
I found the difference after the slant was installed in to to car. New high stall converter came with bigger screws than stock.
Yes, it was possible to manually enlarge all 4 flexplate holes from 5/16” to 3/8” without removing the engine. :D
PostPosted: Sun May 23, 2021 7:27 am
I've never seen 3/8", only 5/16" and 7/16"
PostPosted: Wed May 26, 2021 4:38 am
My mistake. I am from metric side of the world. These bigger bolts are pain. A green Loctite can not keep them tight. I am going to try mig welder next step.
PostPosted: Wed May 26, 2021 5:47 am
How about "BLUE" locktite? That's what I always use, and never had a problem.
PostPosted: Wed May 26, 2021 8:54 am
I use RED Loctite 271 and also Locking fasteners on the Race car.
https://www.stage8.com/product/8967a-fo ... plate-kit/
your thread size / pitch / Diameter might be different, especially if metric.
PostPosted: Wed May 26, 2021 10:10 pm
Probably Loctite uses different codes and colors here. Green is for ”no need for reopening”. Blue is one step weaker. I have not had red Loctite but I have it seen mentioned in the literature.
Also the threads are bit loose. Converter is custom built for me - not modified. A small diameter one with 3500++ stall :lol:
PostPosted: Thu May 27, 2021 4:59 am
Thanks for the replies everyone! I'm leaning towards Rick's suggestion from 440source.com.
As a backstory, I had ordered a 2,800-RPM high-stall street torque converter (for my long-rod street performance rebuild) from Andre at Edge Racing Converters (mentioned here often). All his converters come with 3/8" bolts - why not the standard sized 7/16" - who knows? And while he has been super helpful with my converter selection and built a stout unit - his after sale assistance in recommending a flexplate that fits his converter is non-existent.
I appreciate all the input - as usual!
-Chris
PostPosted: Thu May 27, 2021 6:06 pm
Drill a stock one out with step drill bit.
