It is currently Tue Jul 07, 2026 2:37 am
 Post subject: self-stick gaskets
PostPosted: Sat Jun 19, 2021 2:30 pm
Stupid question: Most thermostat gasket you buy these days have a self-stick coating on one side. Does it matter which side faces the block? Is there a hack to remove the sticky adhesive so you can use your favorite gasket sealer?
 Post subject: Re: self-stick gaskets
PostPosted: Mon Jun 21, 2021 5:34 am
I can't think why it would matter. I would probably put the sticky side on the head surface. If that is clean and flat, no gasket sealer required on that side, and just put sealer between gasket and tstat housing.
PostPosted: Mon Jun 21, 2021 7:29 am
In any application, I put the "sticky" side toward the thermostat. That way it helps to keep the T-stat from slipping out of place.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
