It is currently Sat Aug 15, 2026 11:29 am
Post new topic  Reply to topic  [ 616 posts ]  Go to page Previous 125 26 27 28 2942 Next
PostPosted: Tue Jun 29, 2021 2:55 pm
https://24hoursoflemons.us19.list-manag ... 68627a12a4
Our 17 seconds of fame for winning Organizer's Choice award...
PostPosted: Tue Jun 29, 2021 5:28 pm
Exactly where in the 18 min video is your 17 seconds?
PostPosted: Wed Jun 30, 2021 4:07 am
Very close to the end. Right after the award they gave to the red new age T-Bird.
Roughly 15:30 into it.
PostPosted: Wed Jun 30, 2021 4:46 am
17 seconds that will last a lifetime.
PostPosted: Wed Jun 30, 2021 4:53 pm
They called Escape Velocity Butt Terrible… again… :(
PostPosted: Wed Jun 30, 2021 9:59 pm
You are now immortalized in history!
PostPosted: Fri Jul 16, 2021 5:49 pm
Rob, any updates on improvements for Toad Racer?
PostPosted: Sat Jul 17, 2021 8:10 am
I can give a little rundown next time I'm on!
PostPosted: Sat Jul 17, 2021 3:18 pm
This might be the weekend Rob is moving.
PostPosted: Tue Jul 20, 2021 7:17 pm
Quick rundown: (thanks to Joe, Adam, Rob, and Brian)
1) Engine pulled, oilpan resealed (obvious rear pan seal leak area), ported head (stock valves and near-stock chambers) installed
2) Shifter cable ordered to replace melted one
3) 11.75" discs and caliper adapters and spare EBC pads ordered
4) Fool with seat mounting and back brace to make changes easier during pit stops
For the NCM race in Sept, the plan is to have 20+ more HP on tap, a heat shielded shifter cable, and better brakes. Maybe bigger tires too?
No huge changes, but up the ante a bit and keep it reliable.
PostPosted: Wed Jul 21, 2021 5:13 am
Thanks for the update.
Don't forget some floor insulation for the drivers feet, and some better interior ventilation. Just a reminder.
PostPosted: Wed Jul 21, 2021 6:17 am
Ah, thanks Charlie! I did not recall the drivers fee problem, but I remember now that they blocked the cowl vent so we need to at least open that up.
PostPosted: Wed Jul 21, 2021 6:37 am
I thought someone mentioned about their feet getting hot.
PostPosted: Thu Jul 22, 2021 4:43 am
You could be right. Cowl vent should help that too. Hopefully it will be as reliable as last time (or better) and a bit faster and easier to drive. More powah next after this race.
PostPosted: Mon Jul 26, 2021 1:51 pm
Yep, some insulation in that area will be a good thing. On my last stint Sunday I had to keep lifting up my heel cuz it was awful hot down there!
