It is currently Sun May 10, 2026 10:54 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Jun 28, 2021 9:38 pm
The one thing to check engine off full throttle , if things are to far off metering rod can go to high and come out of jet. If that should happen carb will not return to curb idle.
PostPosted: Mon Jun 28, 2021 9:55 pm
There is a gap, room for movement between the rich and lean piston stops, the step-up spring handles this. It is a tuneable part,modern day eledbrock springs will work.
PostPosted: Thu Aug 05, 2021 11:04 am
PostPosted: Thu Aug 05, 2021 11:12 am
That white 0.010 shim, if that was in place during adjustment ,that extra gap would allow the vaccum piston,under high vaccum to pull rods down an extra .010 Leaner.
Users browsing this forum: cpreal and 3 guests
