It is currently Mon Oct 12, 2026 2:33 am
PostPosted: Tue Sep 28, 2021 6:29 pm
Car Model: Slant Six M37
Does the 1945 suffer the same top cover warping as the BBS does?
I've put a new float in this carb, and it is still letting fuel leak out around the top cover, as well as at the base plate.
Also put a new brass float in, and reset the float level down a bit. That may have helped, but it sure did not solve the problem.
what am I overlooking?
PostPosted: Wed Sep 29, 2021 8:26 am
Try doubling up on airhorn-to-main-body gaskets. Make sure both gaskets are exactly alike, and are the correct ones.
PostPosted: Wed Sep 29, 2021 9:21 am
Great idea Dan. Thanks..
I think I will also reassemble it with out the accelerator pump linkage attached, so I can take the air horn off and check the float level when it is installed on the engine. I appreciate the ease of service of the BBS/BBD carbs the more I get to futz with this Holley.
PostPosted: Wed Sep 29, 2021 9:45 am
https://www.slantsix.org/forum/viewtopi ... ilit=float
PostPosted: Wed Sep 29, 2021 6:08 pm
Image visual fuel green dots always above power valve stem up or down Image with the power vale stem pushed up its just below the air holes in the main well wild guess fuel level, should around the dots.. measure and keep notes in your tuner book
PostPosted: Wed Sep 29, 2021 6:28 pm
PostPosted: Wed Sep 29, 2021 6:48 pm
That is picture of Accelerator pump well, 1945 fills from top no check ball. So lowest fuel level should be close to top of spill way, bottom of ruler is at bottom of spill way or cover entire pump well. No spec for actual fuel level.
PostPosted: Wed Sep 29, 2021 7:59 pm
One thing that seems to work when putting carb back together with used parts. Put top of carb in freezer ,that will shrink down the pump cup. While main body of sits on warm engine.
PostPosted: Wed Sep 29, 2021 8:50 pm
Am I understanding that "as long as the fuel level is high enough to spill into the accelerator pump well" there is enough fuel in the carb for proper functioning?
PostPosted: Thu Sep 30, 2021 7:10 am
Maybe the idle and off idle would work ,pump shot would work. Maln system unsure ,working on this now.
PostPosted: Thu Sep 30, 2021 9:33 am
Short video on air bleed main system https://www.youtube.com/watch?v=aJMXh5F ... assKustoms
PostPosted: Thu Sep 30, 2021 10:16 am
As can be seen in that video the fuel level relative position to the air holes is important at least in my opinion. High fuel level main system start to early and too rich not enough air in mixture. Low fuel level main system start to late and air holes above fuel level, too much air mixture too lean.
PostPosted: Thu Sep 30, 2021 11:20 am
https://www.slantsix.org/forum/viewtopi ... 6&start=15 The last 5 posts have pictures
PostPosted: Thu Sep 30, 2021 12:36 pm
PostPosted: Thu Sep 30, 2021 12:57 pm
Users browsing this forum: Google [Bot] and 7 guests
