It is currently Thu Nov 26, 2026 7:32 pm
 Post subject: Cam Guru Vocublary Help
PostPosted: Tue Nov 16, 2021 4:53 am
I have been starting to do some David Vizard Research.
Can anyone help me understand the difference / similarity in these Cam terms?
LCA - Lobe Center line angle - Mr Vizard uses this term in his writing.
He describes the Lobe Centerline angle as being Narrow vs wide...
Is it the same as.. LSA - Lobe Separation Angle? as I understand that one.
Thank you!
PostPosted: Tue Nov 16, 2021 6:49 am
Yes, David Vizard uses LCA when speaking of the angular displacement between the center-lines of the intake and exhaust cam lobes which is the same as LSA.
PostPosted: Tue Nov 16, 2021 7:40 am
Thanks Joshua - Much appreciated.
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
