It is currently Sun Jun 14, 2026 2:17 pm
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 1106 107 108 109 110128 Next
PostPosted: Tue Nov 23, 2021 5:06 pm
They also changed some of the fuel supply pieces, I forget what they were called.
Man, I would really LOVE a set of webers.
PostPosted: Thu Nov 25, 2021 4:47 am
Yes, those should pick you up a bit, Rick. Tilley even went to 42s, IIRC.
PostPosted: Thu Nov 25, 2021 5:42 am
Well, I didn't get them ordered yet so I will check into 42's also.
Thanks!
PostPosted: Thu Nov 25, 2021 9:51 am
You are now forcing me to build the big motor for sure. :lol:
PostPosted: Thu Nov 25, 2021 10:11 am
Bring it on! :D :D
If you go too fast I will just bore mine out and add some compression too! :mrgreen:
PostPosted: Thu Nov 25, 2021 1:07 pm
:lol: :lol:
Then I add nitrous, you add a turbo.....
PostPosted: Thu Nov 25, 2021 6:03 pm
Wow! This is fun!! :D :D Let's hope we meet up somewhere this coming year!
PostPosted: Thu Nov 25, 2021 7:20 pm
It appears I may have more time to travel next year soooooo..........
PostPosted: Fri Nov 26, 2021 7:03 am
Don't trust my memory completely, Rick. 40s will be almost identical to 42s, and it might run a little better since the venturi size is more different than the main throat?? Worth reading about if you can find materials, tho.
PostPosted: Fri Nov 26, 2021 9:05 am
Yes Lou, that is what I found. I really did not find the 42's for sale anyway. It looked as though the 40's would be fine so I ordered them. I have to try and keep ahead of Dennis. :D :D
PostPosted: Fri Dec 17, 2021 1:07 pm
I got the 40MM venturis last week and I also ordered 2 new sets of air jets and 2 new sets of fuel jets. It sounds as though once you increase the venturi size the jets need to go a size or two larger due to less pressure drop through the larger one. Once they get here I will swap them in and take it for a test run. (Roads and weather permitting) :lol: :lol:
PostPosted: Mon Dec 27, 2021 12:52 pm
I got all my parts to swap in the 40MM venturis on my Webers. But I thought it best to take a peek inside the top covers and see what things looked like before I made the changes. I'm glad I did. There was a lot of "crude" in there in my opinion. So I went ahead and disassembled them and dropped them into our ultrasonic cooker for a good cleaning. Since everything, and I mean everything, is adjustable there are a lot of parts to these. I will let you know if it runs at all after I get all 3 cleaned. :D :D
PostPosted: Mon Dec 27, 2021 2:51 pm
:shock: :shock: :shock:
PostPosted: Mon Dec 27, 2021 9:09 pm
Rick, is that ‘crud’ varnish left from the gasoline in the carb evaporating over time?
If so I wonder if there is someway to fully drain the gas from the carburetor between use?
My bet is that slant is going to run stronger after you get those carbs cleaned.
PostPosted: Tue Dec 28, 2021 4:41 am
John, I think you are correct.
Users browsing this forum: Google [Bot] and 7 guests
