It is currently Wed May 13, 2026 11:12 pm
PostPosted: Thu Dec 16, 2021 7:52 pm
Car Model: Mazda RX8 slant six swap
I am in need of a two groove water pump pulley. What did they come on? Where should I look?
 Post subject: D
PostPosted: Thu Dec 16, 2021 8:54 pm
D
PostPosted: Fri Dec 17, 2021 4:38 am
Car Model: Slant Six M37
Junkyard. Late 70's to 1987 Trucks and Vans.
Or post to parts wanted and see if someone has one on the shelf...
Be wary that mopar small and big blocks also could come with these but the offset is wrong for belt alignment.
Agreed!
In my experience, early 70's (at least through 74, maybe through 76) fan belts and related pulley's have a different belt spacing than the small block stuff in the mid 80's. I grabbed a water pump pulley from the salvage yard this spring with out checking thinking it would fit my 3 groove crank pulley. NOPE! That 3 groove pulley was advertised as fitting 74-77.
Lucked out and the yard had a 74 D600 with a two groove pulley that worked. I also found I have a pulley off a 72 360 that had the correct spacing, but It came out of a 62 D500 long ago, and I have no idea if the pulley belonged to the 62 or 72 water pump...
PostPosted: Sat Dec 18, 2021 8:14 pm
My slant powered 75 and 76 Darts and 76 Aspen had 2-grooves to run the air conditioning. Don't know much more than that.
