It is currently Thu Jul 16, 2026 10:23 am
Post new topic  Reply to topic  [ 913 posts ]  Go to page Previous 147 48 49 50 5161 Next
PostPosted: Sun Dec 19, 2021 7:00 am
I will say that if it didn't go north of 300 you might as well toss it in a dumpster.
HP or Torque…? :?
Never mind… We’re good on both counts… :wink:
Looking forward to my visit with Howard tomorrow.
PostPosted: Sun Dec 19, 2021 2:53 pm
thats great news! my high compression engine with a comp .540" lift and 264@0.050" cam i would shift it at 6500rpm`s and over the line was 6700rpms!
PostPosted: Sun Dec 19, 2021 3:02 pm
It’ll cause me a little concern at first, but I plan to let it fly…. I s’pose… :shock: :lol:
I’ll leave the 7000 chip in it though I think… Maybe 7200…
PostPosted: Sun Dec 19, 2021 3:44 pm
One honest bit of advice Rob, if you don't wear ear plugs in the car now, start. :shock:
PostPosted: Tue Dec 21, 2021 8:14 am
Good advice. Will do.
I’ll post more later about the changes Howard and crew made and the things they discovered.
That dyno time sure is a great tool to figure things out. No way I would have ever gotten it where it is without Howard’s help.
PostPosted: Tue Dec 21, 2021 11:15 am
I was mistaken about the initial pull power numbers… It was even worse… :(
They put it on the dyno just like I dropped it off (just like the doo doo at London).
They aborted that pull at 4000 RPM when the HP was only at 116.7! :shock:
It was the torque that was around 150 (153.2)… :(
Things Howard, Chuck and Tommy changed:
Replaced stock distributor with locked one and a crank trigger.
Adjusted timing from 36 to 23 (where the engine seems happiest now)
Basically gutted the Ron’s Flying Toilet “Pill Box” and installed an in-line quick-change Kinsler pill holder.
Replaced long tube headers with shorties (gasket was leaking as well)
Re-worked all the oil and fuel lines, remounted oil and fuel pumps.
Replaced wire connectors at coil and wired crank trigger, etc.
This is a very abbreviated list and doesn’t account for all the time and effort Howard put in. I’m forgetting things too, I’m sure.
Weight savings so far:
Long tube headers were 36 lbs compared to shorties at 20 = 16 lbs
Exhaust pipes at 22 lbs will be replaced with something much lighter = ??
Fittings and lines= 5 lbs
I will be replacing the radiator and water pump with smaller, lighter ones = ??
I plan to replace the funky monkey bar halo roll cage pieces with simple door bars = ??
We all assumed that replacing the old style Ron’s vane style fuel pump with the new Waterman pump would require a leaner set up. However, I was running a 96 pill when I went 7.49 last year. It is now happiest with a 70 pill! :shock:
So it wanted quite a bit More fuel!
I will try to make/find time to get the Challenger put back together.
Hoping to make some passes in 2022.
PostPosted: Tue Dec 21, 2021 12:19 pm
So did you get a HP number from the dyno pulls??
PostPosted: Tue Dec 21, 2021 3:09 pm
Poser
https://www.youtube.com/watch?v=R6dm9rN6oTs
Come on Mater - SPILL THE BEANS!
PostPosted: Tue Dec 21, 2021 5:04 pm
Yep. Sure did… :wink:
I’ve been accused of sharing a bit much at times….
So, I’m gonna take a page outta Howard’s book on this one…
“Oh… It oughta run purdy good…” :lol: :mrgreen:
PostPosted: Tue Dec 21, 2021 5:39 pm
I understand! Now that you have lots of HP you aren't going to go racing! :D :D Sorry, Couldn't help myself. :D I hope it runs as well as you hoped it would.
PostPosted: Tue Dec 21, 2021 8:42 pm
Well,… the engine made good power on the dyno… no promises now that it’s back in my Poser hands…
PostPosted: Wed Dec 22, 2021 6:25 pm
Do you remember if the new headers were 1 1/2" or 1 5/8" OD?
PostPosted: Wed Dec 22, 2021 8:46 pm
I’m not sure Seymour, but I can check.
PostPosted: Thu Dec 23, 2021 8:58 am
Clifford shorties are all 1.5", IIRC.
PostPosted: Thu Dec 23, 2021 4:43 pm
Well,… There ya have it! 1 1/2” it is.
