It is currently Fri Nov 27, 2026 12:17 am
PostPosted: Wed Jan 05, 2022 9:25 pm
With a 3.500" bore, flat top pistons -.010" down, a gasket compressed .039" and a 56 cc chamber what would I be at for CR?
Thanks! :mrgreen:
PostPosted: Wed Jan 05, 2022 11:42 pm
http://www.wallaceracing.com/cr_test2.php
PostPosted: Thu Jan 06, 2022 12:27 am
Thanks! :mrgreen:
Actual stroke please....
PostPosted: Thu Jan 06, 2022 3:08 am
If I looked at it right, and using a 3.66" big bore gasket, it came out to 11.1 CR. Please double check my numbers! :D
PostPosted: Thu Jan 06, 2022 6:51 am
One Million To One!
PostPosted: Thu Jan 06, 2022 7:24 am
I get 11.2:1 with that gasket thickness and assuming stock 4.125" stroke.
PostPosted: Thu Jan 06, 2022 12:31 pm
Thanks everyone! Yes, stock stroke.
PostPosted: Thu Jan 06, 2022 3:59 pm
I get 11.2:1 w/a 3.55" gasket bore.
Edited; fat fingered gasket thickness.
PostPosted: Thu Jan 06, 2022 4:23 pm
One Million To One!
:shock: I need You to manage a Roth IRA for Me, if Ya ain't busy, lol!
PostPosted: Thu Jan 06, 2022 7:19 pm
I also came up with 11.2 to 1 CR
Get a big cam with the intake valve closing around 75* ABDC and you get 8.17 effective compression.
PostPosted: Thu Jan 06, 2022 7:32 pm
It won't make a huge difference, but you really need the compressed volume of the gasket. Most of the better gaskets have that printed on the packaging.
PostPosted: Fri Jan 07, 2022 5:17 am
I always measure my compressed thickness with head torqued on motor with feeler gauges. Felpro is 0.034, ACL is 0.046, Permaseal is 0.047. These are all pretty close to +/-0.001" measurement error and I have seen variations of +/-0.002".
PostPosted: Fri Jan 07, 2022 7:00 am
I doubt many if any of the gasket suppliers for the Slant 6 engine (except for maybe the MLS Group buy) have the compressed thickness advertised...
PostPosted: Fri Jan 07, 2022 9:00 am
If You're actually cc'ing everything, that's the best way to get as close to perfect as possible. Using dimensional calc. methods, the uninstalled-previously compressed dim. offsets to some extent the volume unaccounted for in the upper piston to bore gap above the ring.
PostPosted: Fri Jan 07, 2022 2:44 pm
Interesting video from the "Riding with Alex Taylor" youtube channel that raising the compression may not be a all that desirable. As it limits the "tuning window". Especially if using power enhancers.
https://www.youtube.com/watch?v=jGHxF_5xvJE
But then they are playing in a difference league then we are.
Users browsing this forum: Amazon [Bot] and 20 guests
