It is currently Mon Oct 26, 2026 6:14 am
Post new topic  Reply to topic  [ 65 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Thu Feb 24, 2022 12:41 pm
I currently have a 83 d150 slant six 1bbl and I'm having an issue with hard start when it's warm sunny out. When it starts to cool down or overnight it starts right up. Ill drive it around and stop it and still starts right up. But when i let it sit for about 4 hours in the sun it hard to start after several tries whats going on.
PostPosted: Fri Feb 25, 2022 9:50 am
Car Model: Slant Six M37
Hard to start as in the engine turns over slowly and does not catch, Or lots and lots of cranking to get it to start?
Fuel line mod
PostPosted: Sat Feb 26, 2022 7:06 am
Lots of cranking to get it started
PostPosted: Sat Feb 26, 2022 7:10 am
Thank you. I will replace and see what happens. Is this a comman issue with the d150s?
PostPosted: Sat Feb 26, 2022 7:44 am
It's Probably common with any Slant 6 in OE configuration with the stock Fuel Line and Modern Fuels.
PostPosted: Sun Feb 27, 2022 4:16 pm
Question so with the fuel filter with the 3rd nipple where would I connect the return hose to? Is it somewhere in the sending unit?
PostPosted: Mon Mar 07, 2022 7:58 pm
I haven't had a chance to fix it but there is also some other issues when the engine is hot and I'm driving it will randomly shut off.and I have to keep on cranking it for it to start. Will the fuel line mod fix this issue or could it be something else.
PostPosted: Tue Mar 08, 2022 3:08 am
Does it still have the Lean Burn ignition system on it?
PostPosted: Tue Mar 08, 2022 3:38 am
I have no clue. Where is it located at? What does it look like?
PostPosted: Tue Mar 08, 2022 6:24 am
I did that to mine and it didn't do diddly squat to make it any better! YMMV. Good Luck
PostPosted: Tue Mar 08, 2022 10:01 am
How did you fix the problem?
PostPosted: Wed Mar 09, 2022 6:25 am
I've learned to live & deal with it, and NOT put myself into situations where it happens! If it does happen, I hold my foot to the floor and crank till it fires. It's a flood/vapor lock type condition that's happening, nothing you do can fix it because it's the gas that's the problem. Good Luck
PostPosted: Wed Mar 09, 2022 10:14 am
So if it's modern gas isn't their some sort of aftermarket pump? As well as replacing all the hoses to more modern?
PostPosted: Wed Mar 09, 2022 7:03 pm
It's not; that's the kind of sour-grapes excuse sometimes used by those who won't admit the limits of their knowledge and ability.
It's good practice to go through and replace all your flexible fuel hose with fuel injection hose marked 30R9. The problem isn't being caused by your fuel pump not being the right type (or being incompatible with modern gasoline, etc).
Other things to check: make sure your manifold heat control valve isn't stuck in the heat-on position, and make sure your carburetor is in tip-top condition with a correctly-adjusted float (that hasn't absorbed gasoline and gone heavy) and the correct thick, insulating base gasket. Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download, and tune-up parts and technique suggestions in this post. A further modification to reduce the tendency of engine heat after shutdown turning the carburetor into a boiling teakettle is to make a heat shield. There was a factory item, but it has been unavailable for many years, so this would be a make-it-yourself item. Diagram is in this thread.
