It is currently Mon Jun 15, 2026 3:31 am
PostPosted: Sat Feb 26, 2022 7:14 am
Car Model: 63 Valiant 100 65 A100 pickup
Hey guys, Got a 63 Valiant /6 with a Torqstorm supercharger 4speed, been running a couple a years now. Have a Brewers 10 inch clutch kit in it, but it has a lot of pedal pressure. It does not disengage well and is hard to get in any gears. I would like to replace it with a new disc and diaphragm pressure plate with a little more pressure than stock. 25 plus years ago I used to run a Zoom clutch kit and it did very well, but am told Zoom has been bought out. Any help would be great.
Thanks , James
Own 65 A100, 63 Valiant v100
PostPosted: Sat Feb 26, 2022 2:36 pm
Sounds like a great car! RAM clutches now has several options for the Slant with big holding power. I assume you are running the 833 4spd?
PostPosted: Sun Feb 27, 2022 4:45 am
When you put that combo together did you check and adjust the bell housing runout and minimize it?
If not, which is many a mistake of mine a while back, then in will cause issues as you described with the clutch and plate.
Ram does have some skookum as frighted options now for the slant.
Cheers!
PostPosted: Sun Feb 27, 2022 7:19 am
Hello Lou, I will contact RAM monday. Thanks
PostPosted: Sun Feb 27, 2022 7:24 am
Greg, I will research this runout problem. I don't understand why it did so well for about a year and slowly got to this point? Checked each individual linkage part for flexing and or cracks. Thanks, James
PostPosted: Mon Feb 28, 2022 4:45 am
Hi James, sometimes the runout being off will be fine for a year or two but it aggressivley wears the internals and alignment of the trans shafts ℄'s so It can work fine for a while then be hard to shift.
you said that you checked the linkage and everything - But double check your Z bar ..
on early ('62-'66) cars with heavy pedal pressure they can fail.
Lookhere for some of my experience and fix.
