It is currently Fri Nov 27, 2026 2:20 pm
PostPosted: Tue Mar 01, 2022 7:40 am
Car Model: custom roadster
I tried this question on a Facebook group, but the discussion may have veered off on a misunderstanding. Yes or No: Do 1973-and-newer spool-type engine mounting brackets fit early (1961-ish) 170ci slant blocks?
I have one set of brackets and one early block that don't want to work together because the base of the dipstick tube is (just barely) in the way. I'm trying to determine whether that's because (1) spool mounts generally don't fit early 170ci blocks or (2) my left side bracket has bolt holes just slightly off where they should be and/or this block's dipstick tube is a bit further forward than normal.
PostPosted: Tue Mar 01, 2022 3:48 pm
yes
PostPosted: Tue Mar 01, 2022 6:55 pm
yes
Great to know! Thank you, Kesteb.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
