It is currently Tue May 12, 2026 6:57 pm
 Post subject: Oil Pan and Timing Cover
PostPosted: Thu Jun 23, 2022 11:14 am
Car Model: 1962 Dodge Dart 330 Sedan
Getting ready to reassemble my 62' Slant 6 and wanted some wisdom from the experienced on ways to make sure that I don't have leaks from the oil pan and/or the timing cover. Much thanks - gpk1961
PostPosted: Thu Jun 23, 2022 9:17 pm
Car Model: 1975 Dodge D100
Check the Articles page. Lots of cool stuff over there.
Here’s a link:
https://www.slantsix.org/articles/gaske ... n-seal.htm
I recommend Doc’s book too.
https://www.amazon.com/Chrysler-Slant-S ... 153&sr=8-1
I used this book as a guide and was able to complete my first slant rebuild with confidence.
Good luck with your project!
PostPosted: Fri Jun 24, 2022 5:23 pm
Thanks! I just found and ordered that book...good recommendation and thanks for the article - I forget to check the articles page.
I am gathering parts and have the long block on the engine stand, ready to get started.
GPK1961
PostPosted: Mon Jun 27, 2022 6:21 am
Is the engine out and on a stand? if so It goes together easiest with the timing cover assembled first.
- Start with a helping of RTV - I like Permatex Grey (but any flavor will probably do)- placed on all of the cork/paper side wall junctions to the rubber ends - especially in the corners.
- Set the pan on / Start all bolts loose but do not tighten or torque to spec yet.
Let the RTV "flash off" for 4-24 Hours
- Final Torque the pan Down
- It's possible you may still have a leaker in the Lower RF Front Corner.. By the Timing Cover.
- You can RTV over the outside of the Pan to Timing cover Junction here if you want.
I am sure others have some sage advice and techniques that they prefer and may chime in here.
Best of luck.
PostPosted: Mon Jun 27, 2022 3:39 pm
Thanks Greg - yes it is on the engine stand. I have the timing cover ready to go and I am waiting for an oil pickup tube.
It had very minor leaks before the rebuild and I am hoping to keep it that way! Thanks for the tips! gpk1961
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 5 guests
