It is currently Fri May 08, 2026 12:58 pm
 Post subject: Re: Timing chain help
PostPosted: Fri Jul 08, 2022 2:39 pm
Out-of-index distributor is more likely than jumped timing chain; see here.
If you want to check for a slack timing chain, that's easy; see here.
Fixed the issue had to replace the coil again and ignition. Now I'm having a start and run issue. With the air filter on it start but when the engine start to warm up it dies. So I remove the air filter and it drives. Is this a vacuum leak or is this something I have to adjust .
PostPosted: Fri Jul 08, 2022 6:16 pm
Did you plug all the vacuum fittings on the carb that were open? Did you check for vacuum leaks around the carb, intake, etc.
If it runs , check your timing and get it set. Adjust idle and idle mixture.
What exactly do you mean by ignition? The ignition module? The distributor?
PostPosted: Sun Jul 10, 2022 3:00 pm
Are the vacuum fittings all the open holes on the carb? Yes the coil and ignition module. Is my distributor supposed to have a relay?
PostPosted: Sun Jul 10, 2022 4:36 pm
No not normally. Can be a relay if someone switched the ignition system over to the HEI module.
Not necessarily. Check if you have vacuum on them when it is running. Or spray a little 2+2 into the open fittings. It will shut the engine off or change its sound greatly.
Did you set the timing and adjust the carb?
You may do well to post a video for us to see exactly what it is doing.
Users browsing this forum: Bing [Bot], Charrlie_S, Google [Bot] and 4 guests
