It is currently Sat Jul 18, 2026 7:56 am
PostPosted: Sat Jul 23, 2022 10:13 am
Car Model: Slant Six M37
I assume they are for fuel efficiency, and helping to vaporize fuel that has not made the turn into the intake runner.
Thinking of trying it on a 1bbl intake as I convert it to a parallel 2bbl intake.
Any thoughts, reactions, and suggestions welcome.
PostPosted: Sun Jul 31, 2022 7:05 am
Car Model: 1966 Dodge Dart
I think it's meant to trap liquid fuel until the heat of the manifold can vaporize it. Stock manifolds are bond to the exhaust system and already pretty hot, but some of the aftermarket designs have no provision to bolt to the exhaust heat riser. So I'm not sure I would bother adding one unless you're using headers.
Matt Cramer
PostPosted: Sun Jul 31, 2022 10:09 am
Most aftermarket manifolds are cast aluminum. I'm thinking they might be strengthening ribs possibly to help prevent cracks?
PostPosted: Mon Aug 01, 2022 7:16 am
I have been wondering on how to improve the factory intake manifold since reading DD's observations-experience about cylinders 2 and 5 being lean when compared to cylinders 1 and 6.
viewtopic.php?f=19&t=65856&hilit=87+octane&start=15
PostPosted: Mon Aug 01, 2022 7:22 pm
To even out the fuel at each cylinder the easiest way is to Install multi port fuel injection.
With a MS ecu and probably other aftermarket ecu’s one can make adjustments to each injectors dead time / on time to equalize the cylinders.
PostPosted: Tue Aug 02, 2022 9:24 am
Often, the most effective way to do this with a carb is to cut grooves in the manifold floor. Use these as channels perpendicular to cylinders that run rich, or pointing down the runner for cylinders that run lean. These guide liquid fuel towards or away from cylinders.
You'll also want to keep tabs on the individual cylinders - plug reading if on a budget, individual EGT probes if you are making a max effort race build.
Matt Cramer
PostPosted: Tue Aug 02, 2022 7:07 pm
Thanks for the suggestion Matt. I will give it a try.
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
