It is currently Mon Nov 09, 2026 1:16 am
PostPosted: Fri Sep 02, 2022 5:38 pm
I have an alternator - non OE Chrysler Type - Nippendenso Small style - 30-40 Amps - Not exactly sure as there is no part # on it.
It may be one of those Kubota Tractor ones. - Internally regulated.
Anyway It has 4 Leads to the from the Diode terminals / block to the stator coils..
If I test for continuity between the Stator coil leads (any of the four) and the Stacked Stator Frame (steel laminations) I should get an open circuit / no resistance correct?
Thank you,
