It is currently Sat May 23, 2026 5:56 am
PostPosted: Sat Oct 01, 2022 7:20 am
Car Model: 65 D200 and 64 D100
65 d200 /6 np435 tranny
(been driving it to and from work with a problem)
Was on my way home getting on hwy got on it a little backfired and died couldn't get to start back just backfire through the carb gonna start with adjusting valves and go from there thinking maybe it jumped timing but just guess atm any suggestion?
when i bought him https://imgur.com/OQCEnOR
2 years later https://imgur.com/NREhdRa His Name Is Fred
PostPosted: Sat Oct 01, 2022 7:46 am
Make sure to pop dist cap off and see if the distributor is OK. The nylon drive gear might have sheared, or other things could have come apart. Nylon gear is common failure. You could just check for spark first, also. Could have broken timing chain or skipped it, and that would show up when you crank and look at valves opening and closing and/or a compression test. Good luck!
PostPosted: Sat Oct 01, 2022 12:13 pm
Still got spark distributor seems fine timing mark looks off guessing timing chain jumped
Tried adding pic says it's to big
PM it to u
never mind it wouldn't let me send that way either it about 1/4 turn past where it should be gotta make a tool to pull damper pully off so I'll let ya know what I find after I get off work Monday
best i could do is the imgur link there that is where the timing light goes off when it should have been at 0 for first cylinder
https://imgur.com/a/W1aiwWy
PostPosted: Sat Oct 01, 2022 2:08 pm
Either of the Things that dart270 says are viable.
Good to replace both while you are figuring things out.
PostPosted: Sun Oct 02, 2022 4:19 pm
welp i think u was right about distributor drive gear
pic of mine
https://imgur.com/DyCVQBA
cant find/get one atm back order so went to parts truck :lol:
https://imgur.com/FmXhgqc
parts truck gear and old gear
https://imgur.com/uRFo1fF
got it retimed and everything started it got excited shut it off went inside to get a drink (didn't have radiator back on yet) came back out got radiator back in and full wouldnt start back up kinda same boat as before so pulled distributor (i put lithium grease on it)
https://imgur.com/QvrFrYl
guess i gotta try and find some of this gears rockauto is out and orielly said they was on back order other option is to buy an whole distributor kinda irritating considering all i need is a $10 part lol
PostPosted: Sun Oct 02, 2022 4:28 pm
If it keeps Shearing plastic gears. It is possible that the Drive Gear on the Cam is starting to go bad.
No real way to know unless you put a borescope in the distributor hole and See what's going on or pull the cam/Oil Pump for inspection.
New Gears available from forum Member badvert Here
PostPosted: Sun Oct 02, 2022 4:30 pm
You can see the drive gear on the cam through the dist hole, but may need a small mirror and a light to see it while the engine is in the truck (tough angle to view).
PostPosted: Sun Oct 02, 2022 5:21 pm
idk if I would say it was the engines fault for the one from the parts truck lol just cause there no telling how long it had been in there/out there i did have some hair line cracks I could see before but ill order some of those and keep them on hand and ill look better tomorrow at the distributor hole/cam shaft gear
PostPosted: Sun Oct 02, 2022 10:15 pm
Does the OP know that the hole that accepts the retaining pin in the distributor gear needs to be re drilled when installing a new distributor gear. If that is not being done excessive end play at the distributor gear will result. The excessive end play can cause broken distributor drive gears.
PostPosted: Mon Oct 03, 2022 3:22 pm
Sounds like my old 79 d100 did to me around 1990. After replacing 3-4 distributor gears the engine happened to be at a spot in it's rotation where I could see the missing tooth on the cam. Got another motor for something like $100 and stuck that in there, that motor was an oil burner/mosquito fogger, I wish I'd have just replaced the cam in the original engine. After discovering that I had bought a mosquito fogger, I converted that truck to a V8. Lots more extra bits to find and replace than I thought there would have been. I didn't know near as much about the /6 back then, not that I know a lot about them now.
PostPosted: Tue Oct 04, 2022 5:43 pm
whelp fellas turns out cam gear is pretty much gone lol
https://imgur.com/KrBEVYd
honestly didnt think the plastic would take out the metal but i was probably doing close to 40-45 when it let go so i guess it can happen search to find a cam is on now as well too i guess
PostPosted: Tue Oct 04, 2022 6:27 pm
after reading online not to buy comp cam not sure where to go there are some places there were listed but apparently they are not there anymore and the Erson one is out of stock sent them an email but anyone got any links
*other option*
might pull the one from my parts truck and give it a once over... opinions?
PostPosted: Wed Oct 05, 2022 3:01 pm
Oregon cams will grind you whatever you want and they usually have blanks.
PostPosted: Sat Oct 15, 2022 4:33 am
Ok finally got all the old stuff off question any reason y this cam got ate up? Kinda feel like it's my fault driving it to hard but figured before throwing it back together id ask oil pump got a little damage ( but never lost oil pressure 40ish when hot) it just the cam gear is what got eat up
Not sure if it's called cam gear but I'm talking about the part that runs oil pump and distributor
PostPosted: Sat Oct 15, 2022 5:53 am
If the oil pump gear is damaged, it will damage the new camshaft. It should be replaced also.
