It is currently Fri May 22, 2026 8:17 pm
 Post subject: cam repair!
PostPosted: Sun Oct 09, 2022 10:10 am
was reading on oregon camshaft that they can repair damaged cams! have anyone done this or is it cheaper to just get a new cam?
 Post subject: Re: cam repair!
PostPosted: Sun Oct 09, 2022 11:08 am
When they ground my current cam onto the core I sent, they offered to repair the fuel pump lobe as it was worn. I elected not to have it done as I am running an electric fuel pump. I am uncertain that they can do anything about the oil pump/distributor drive gear.
PostPosted: Sun Oct 09, 2022 12:02 pm
Give Ken a call at OCG.
In your situation with the international shipping both ways it may be cheaper to get your cam ground on a core that they have in stock.
PostPosted: Sun Oct 09, 2022 12:11 pm
I believe the last cam I ordered from them was @ $160 on their new core. . I have had them repair the fuel pump lobe. $15 a few years ago.
PostPosted: Sun Oct 09, 2022 12:47 pm
ok! thanks! just checking and with canada post roughly $104 cad one way!
PostPosted: Sun Oct 09, 2022 12:51 pm
i`m running a external oil pump! just use the gear to drive the dist! lost #1 intake lobe! second comp cam i have lost just one lobe in the last 5yrs!
PostPosted: Sun Oct 09, 2022 5:01 pm
When he did mine it wound up at $120 for his part of the bill ($80 regrind and $40 for the fuel pump lobe) plus about $60 for a set of new lifters and something like $45 shipping both ways
I was PISSED at the shipping cost and time it took. That wasn't his fault I know..... Cost me double what I was expecting, and took double the time I was quoted for it to get there.
PostPosted: Fri Oct 21, 2022 5:22 pm
Did Comp offer the case hardening to You after the 1st failure? Or were they unaware of it? Service is about $110usd, won't fix tappets made of taffey, but may prevent the lobes from getting wiped out.
PostPosted: Sat Oct 22, 2022 3:25 pm
no they never offer to replace the cam when i only raced it! i never had it happen on the two street engines i build! the second engine had some street time but mostly racing when it did! also when i had stock oil pump it never happened either!
