It is currently Sun Oct 25, 2026 10:03 pm
PostPosted: Mon Oct 10, 2022 11:23 am
I seem to recall a post talking about using an older style head (big plug, drool tube) on a newer 77-79 block. I am not finding it in my searching. They question is whether the pushrod, lifters, adjusters rockers etc will all swap over. Is there any difference in the head gasket I should use. What is the best head gasket.
64 Dart GT Convertible, 225 Super 6, Carter BBD, 14x7 SBP Rally Wheels, HEI, Fuel mod, wiring upgrade, Alt upgrade, 2BBL, headlight upgrade, front disc brake conversion
PostPosted: Mon Oct 10, 2022 11:42 am
That swap will be fine.
Any head gasket will work for a stock engine build. Fel Pro is what I would use.
Just as long as you are not trying to swap a Hydraulic Lifter Head on there with out swapping the cam and other appropriate parts with it.
PostPosted: Mon Oct 10, 2022 11:59 am
Thanks much!
Users browsing this forum: Google [Bot] and 9 guests
