It is currently Sun May 24, 2026 10:56 pm
 Post subject: Oil Pump ate my Cam?
PostPosted: Mon Oct 17, 2022 2:43 pm
Car Model: 65 D200 and 64 D100
best i can tell from looking at it I'm thinking the oil pump ate my cam i bought a Sealed Power Standard Flow/Pressure got another cam in didn't want to just buy another oil pump and be in the same boat shortly afterwards doing this all over again
what pumps are yall using and/or recommendation?
when i bought him https://imgur.com/OQCEnOR
2 years later https://imgur.com/NREhdRa His Name Is Fred
 Post subject: Re: Oil Pump ate my Cam?
PostPosted: Mon Oct 17, 2022 3:01 pm
Do you have photos?
I've dealt with this twice where the cam and oil pump gear got into a disagreement and they lunched each other. What cam are you using? Personally I only run either a stock cam, or a stock core re-ground by Oregon Cam Grinding. As far as pumps, I only run OE pumps, excepting a unit I bought from Doug Dutra that he souped up and put a hardened gear on.
~THOR~
PostPosted: Mon Oct 17, 2022 3:14 pm
Do you have photos?
~THOR~
as far as i know it was stock cam and it was sealed powered oil pump from rockauto
sorry only way i know how to link photos
https://imgur.com/SWbLoOP
https://imgur.com/hVkErpD
https://imgur.com/Cvs70Ry
https://imgur.com/SdQRkzv
https://imgur.com/dBOxVpV
https://imgur.com/dXU7t2a
https://imgur.com/E30u3yr
https://imgur.com/fEi2XZ9
PostPosted: Mon Oct 17, 2022 3:28 pm
To help diagnose this, you need to answer some questions:
1) Who made the cam?
2) Who made the oil pump?
3) What timing chain was used?
4) Are you running a windage tray?
5) Are you running a cam stop?
6) Where any oil system modifications made?
7) Where any oil pan modifications made?
PostPosted: Mon Oct 17, 2022 3:31 pm
1) Who made the cam? umm dodge
2) Who made the oil pump? sealed power
3) What timing chain was used? umm dodge
4) Are you running a windage tray? no
5) Are you running a cam stop? honestly dont know what that is so no
6) Where any oil system modifications made? i changed from orginal oil pump to spin on filter oil pump
7) Where any oil pan modifications made? nope
PostPosted: Mon Oct 17, 2022 3:44 pm
Well, at this point you'll need another cam and at least a new gear on the oil pump. Did you lubricate the oil pump gear with engine assembly lube when you installed the new pump? If not, those gears will start to eat each other pretty quickly. A lot of heat is generated due to the force required to turn the oil pump.
We used to buy Melling oil pumps, but they've been unobtanium new for years now...
~THOR~
PostPosted: Mon Oct 17, 2022 4:10 pm
~THOR~
yep got another cam installed this weekend and new timing chain sprocket was gonna order another oil pump but more i looked at this one the more i questioned it i didnt want to say how long the oil pump had been on there because i dont drive it daily but i put that one on there back in feb 2021 so maybe driving wise 4-5 months maybe less yes lubricated the oil pump everything assembly lube ive been a diesel mechanic for 15+ years
PostPosted: Mon Oct 17, 2022 7:27 pm
Eh? There is nothing such as a "spin on filter oil pump". All Slant-6 oil pumps accept spin-on filters. If your vehicle originally had a replaceable-elephant (element) oil filter, and you want to use spin-on filters, all you do is remove the replaceable-elephant filter, install the threaded nipple, and then you can spin filters onto the pump all day long (as long as you do it one at a time).
PostPosted: Tue Oct 18, 2022 2:37 am
Ok yea I changed from the element one to the one I got now thinking only difference is new one had spin on filter instead of drop-in filter for simple reason the drop in I couldn't get to seal and quit leaking
PostPosted: Tue Oct 18, 2022 5:41 am
I'll have to see when I get home hopefully I didn't throw it away but I'm betting I did
PostPosted: Tue Oct 18, 2022 7:21 am
I strongly suggest finding a decent used pump to use, assuming the gear wear looks good. I do this on all my engines (as of the late 90s), and they have always worked fine, whether in daily driver street cars or racecars. I have never had an oil pump related failure (knock loudly on wood). I also usually use regrind cams.
My 2 cents...
PostPosted: Tue Oct 18, 2022 4:05 pm
My 2 cents...
well my parts truck (67 d100) has one that looks good gear wise but looks more like the one i have on there now not the older style (my truck 65 d200) (drop in element filter) that was on there when i first got the truck would that one work?
https://imgur.com/TPfYwbL from parts truck
i got 1 more place i can check there a pull parts place that has a 64 d100 with a /6 ill check there on the way home from work tmw to see if it still has the oil pump
PostPosted: Wed Oct 19, 2022 6:45 am
As Dan said, those pumps (and I believe ALL Slant 6 pumps) are the same and interchangeable. Just put a spin on filter on the one you have.
