It is currently Thu May 21, 2026 6:31 pm
 Post subject: Engine intake manifold
PostPosted: Mon Oct 24, 2022 5:21 pm
Car Model: Dodge D-150
Hey does anyone know if a 1977 Plymouth slant six manifold would fit a 1982 dodge d150 slant six?
PostPosted: Mon Oct 24, 2022 5:30 pm
Yes, it will. It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions.
PostPosted: Mon Oct 24, 2022 5:38 pm
Okay thanks a lot, mine has a leak and I’m looking to change it with any parts, an I forgot to mention that it was an intake manifold, still the same right?
PostPosted: Tue Oct 25, 2022 7:44 pm
Car Model: Slant Six M37
Yes they are the same. Your's is aluminum?
PostPosted: Wed Oct 26, 2022 2:59 am
I’m not even sure if it’s aluminum, how do I tell just by looking at it?
PostPosted: Wed Oct 26, 2022 6:45 am
Aluminum is a silverish color underneath the paint. Cast iron likely has a rust sheen, but it is black-grey if you sand or clean it.
Cast iron intakes rarely fail outright. Why are you believing that the intake has a vacuum leak. What leads you to believe the intake has failed? I am not questioning your belief outright, but trying to make sure that it is not something else that is a comparatively easier fix...
It would seem to me that the vacuum leak is in the gaskets, or somewhere else, and not the cast iron intake itself.
PostPosted: Wed Oct 26, 2022 6:47 am
Is a magnet attracted to it?
PostPosted: Wed Oct 26, 2022 7:17 am
Intake manifolds don't need replacement for leaks very often. Sure it isn't just the gaskets?
PostPosted: Fri Oct 28, 2022 6:44 am
The Remeflex gaskets that SlantSixDan suggested work great and that may solve your vacuum leak issue.
PostPosted: Fri Oct 28, 2022 2:11 pm
This thread has been moderated, to remove certain posts, that were not at all constructive.
Users browsing this forum: Bing [Bot], Google [Bot], Nearo123 and 4 guests
