It is currently Mon Oct 26, 2026 1:03 am
 Post subject: Rotating the engine
PostPosted: Sat Dec 24, 2022 10:54 am
63 Valiant slant six.... How can I rotate the engine by hand? I don't see a bolt or other means to rotate it from the crankshaft pully? also assume it rotates clockwise?
 Post subject: Re: Rotating the engine
PostPosted: Sat Dec 24, 2022 11:12 am
You can put a bolt in the crank. 3/4" fine thread, about 2" long and a washer is all you need.
PostPosted: Sat Dec 24, 2022 12:05 pm
Thank you
PostPosted: Sat Dec 24, 2022 12:26 pm
If you have the alternator and fan/ water pump pulley installed then add hand tension the v belt and turn the fan.
PostPosted: Sat Dec 24, 2022 12:30 pm
Pulling all the spark plugs will make it much easier to turn too.
PostPosted: Sat Dec 24, 2022 12:41 pm
Leaving them in saves $20 on gym membership and pists money in your parts and fuel budget. :D
