It is currently Wed May 06, 2026 12:39 am
 Post subject: Ring gap
PostPosted: Thu Dec 29, 2022 11:35 am
Car Model: 1965 A100 pickup
Finally getting around to assembling the engine for my A100 pickup. Need to know the correct ring end gap. Stock motor .030 over.
 Post subject: Re: Ring gap
PostPosted: Thu Dec 29, 2022 6:29 pm
Car Model: Slant Six M37
I'm of the belief that stock pistons and rings come with the gap already set.. Unless you are going to be running a power adder, such as nitrous, or a charger of some type.
PostPosted: Thu Dec 29, 2022 7:09 pm
Rule of thumb is .004" gap per inch of bore. Double for power adders.
PostPosted: Thu Dec 29, 2022 9:04 pm
On occasion one might find the rings one has bought happen to present with an appropriate gap in the cylinders one is working with, but beyond that there is nothing such as rings with a pre-set gap. These aren't spark plug gaps we're talking about; ring gap is a function of how the rings are made and the exact, precise diameter of the cylinder. That's why the correct procedure is to check the gap of each ring in its intended cylinder.
Pistons don't enter into this part of the discussion.
PostPosted: Fri Dec 30, 2022 5:23 am
Dan, essentially you are correct, but there are a few exceptions. Hypereutectic pistons do require an adjustment to ring gap, which is different than cast or forged pistons.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 8 guests
