It is currently Sat Oct 24, 2026 8:13 am
 Post subject: Valve cover torque
PostPosted: Mon Jan 02, 2023 11:41 am
According to my manual, I need to torque my valve cover bolts to 40 Foot pounds. That seems like a lot..... I always thought that those covers can distort easily so
not a lot of torque was needed. Thoughts?
 Post subject: Re: Valve cover torque
PostPosted: Mon Jan 02, 2023 12:56 pm
The torque for valve cover bolts is 40 in-lb. This number is located in "225 cubic inch Engine" section, "Cylinder head installation" near the end of last paragraph. Tighten cylinder head cover nuts to 40 inch-pounds.
40 in-lbs = 3.3 ft-lbs.
Before installing the valve cover, check the bolt hole flange for flatness. Sometimes bolt holes will be stretched or deformed from previous over tightening, and require a few light taps with a hammer to correct the problem.
I use a nut driver to hand tighten these nuts or bolts.
Over tightening will damage a cork gasket, and it will never seal.
PostPosted: Mon Jan 02, 2023 1:33 pm
Ahh, thank you
PostPosted: Wed Jan 04, 2023 5:21 am
I don't think that I've ever used an actual torque wrench on a valve cover.
And for that low of reading don't "convert" the reading to a ft /lb tq wrench, as that's too low for most to even register.
PostPosted: Wed Jan 04, 2023 6:12 am
I posted that 3.3 ft-lbs number to show just how little torque is needed to snug down a valve cover. Most folks can envision exerting a 3 lb force on a one foot wrench, or twice that on a six inch long wrench. 40 in lbs, not so obvious to ones wrenching hand.
Users browsing this forum: Amazon [Bot] and 12 guests
