It is currently Mon Oct 26, 2026 7:24 am
 Post subject: Intake heater
PostPosted: Fri Jan 06, 2023 9:36 am
Car Model: 1965 A100 pickup
I’m going to use an Offy manifold w/Dutra duals. I need to heat the intake, and have read about a hot water block to bolt under the manifold and connect to the cooling system. Anyone know where to get such an item? Thanks,Steve.
 Post subject: Re: Intake heater
PostPosted: Fri Jan 06, 2023 11:48 am
Online
Here is a bit of a write up I found about one.
https://www.forabodiesonly.com/mopar/th ... es.457828/
Good luck!
PostPosted: Fri Jan 06, 2023 12:40 pm
I made one of these water heated hot spots in 2008 to solve a carburetor icing problem with a Clifford shorty intake and headers. It has worked great ever since. I spliced into the heater coolant circuit in series, circulating 195* coolant. I have driven the car in sub zero to high 90's weather with no problem.
I had written this project up in 2008, but can't locate it using search.
PostPosted: Sat Jan 07, 2023 11:24 am
Last item on this page. Frank Raso is a longtime Slant-6er.
PostPosted: Thu Jan 12, 2023 2:56 pm
If the junk yards in your neck of the woods still have old Ford trucks, Ford made a nice water heated spacer for between the carburetor and manifold. There are both 2v and 4v versions. I would look for a F150 with a 390 FE series engine.
PostPosted: Thu Jan 12, 2023 3:03 pm
I have such a creature if you want it. I got it to put between my Holley 350 cfm and modified Super Six intake but never used it.
PostPosted: Mon Jan 16, 2023 9:07 am
Sorry, I have searched the garage and tool room high and low, but I can't find it. It sat right there in the top of my big rolling toolbox for at least 7 years! But nobody knows anything about its current whereabouts. :roll:
Users browsing this forum: Ahrefs [Bot] and 7 guests
