It is currently Sun Oct 25, 2026 2:50 pm
Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Jan 13, 2023 7:10 am
I placed the order with Precision this morning for a pile o' gaskets. I'll keep you all updated on shipping, cost, payment, etc.
Slant on,
PostPosted: Fri Jan 13, 2023 7:49 am
Thanks Lou!
PostPosted: Fri Jan 13, 2023 9:10 am
Let us know the costs and I can get it to you ASAP. Thanks!
PostPosted: Fri Jan 13, 2023 11:02 am
Sounds good!
Last Time I did that they arrived very quick.
PostPosted: Wed Jan 18, 2023 6:25 am
ATTENTION.
I put a note on my order to Precision to check if these were still the big bore gaskets. They responded last night and they are NOT the correct gaskets. It looks like Endurotec changed their process/supplier/design and we can no longer get the big bore gasket. Drat. These are 3.5" bore, like a FelPro.
I have cancelled this order and it seems we can no longer get "the good stuff." Too bad for us, but this is life...
Maybe we can explore other suppliers and/or contact Endurotec directly? I have expended my available effort/time on this for the moment.
Thanks to all for your excitement!
PostPosted: Wed Jan 18, 2023 9:08 am
Well, If we ever get to contact them I could up my order some to get the numbers up if there is a minimum order. I have a couple left, but if we get in a real jamb we can always get a MLS gasket from Ryan in any size we want.
PostPosted: Wed Jan 18, 2023 9:17 am
Thanks for your efforts Lou!
PostPosted: Wed Jan 18, 2023 10:18 am
Thanks for your research in this.
PostPosted: Wed Jan 18, 2023 12:02 pm
Thanks guys. I may get back to contacting Endurotec directly at some point, but right now I am burned out on this, and pretty disappointed.
PostPosted: Wed Jan 18, 2023 7:05 pm
Rick, in round numbers what do the large bore slant MLS gaskets run?
The MLS is superior technology for cylinder head sealing.
Maybe the slant six performance group should be putting their efforts behind the businesses that are manufacturing the products that the group wants?
And, since AussieSpeed can’t get big bore slant gaskets from Endurotec anymore, wonder if they would be interested in purchasing them through Ryan. Being a distributor for what maybe the worlds only big bore slant head gaskets could be an interesting side business.
PostPosted: Wed Jan 18, 2023 9:21 pm
I'm not 100% on it, but FABO member MOPAROFFICIAL, said a large-bore Cometic one-off was either$78 or $87...that was a while back. The Cometic I put on Pop's '87 ShelbyZ was over $100 from Summit, and that was an in-stock item, so I anticipate at least that now.
PostPosted: Thu Jan 19, 2023 3:35 am
Don't quote me but I think somewhere between $175 & $200, Maybe a little more. He did 2 bore sizes. One for stock bores and one for big bores. Your thickness was also able to be changed if you wanted. The more layers the more costly. Ryan ran one for a couple seasons on his 13.5 to one race engine without problems. And it was removed and reused at least once maybe twice. The small bore one was designed with the aluminum engine in mind to try and assist sealing between the aluminum and cast iron. I think Lou is putting a engine together with this combo.
Cometic in 2015 quoted us $350 per gasket with a minimum order of 20
PostPosted: Thu Jan 19, 2023 3:46 am
I have the small bore MLS in my 9.6:1 aluminum engine with about 250 miles on it and some hard use. I have not raced it yet or really burn tested it, but it is working well so far.
PostPosted: Thu Jan 19, 2023 8:52 am
Car Model: 64 Valiant
I had several gasket companies make the big port intake/exhaust gaskets out of copper for the Slant with ported heads several years ago. Both companies also make head gaskets, and while MLS is rated by those companies as being 2 steps superior to a stock composition head gasket, they both rate copper as being 2 to 3 steps superior to an MLS gasket, and they are considerably cheaper and reusable numerous times also.
PostPosted: Thu Jan 19, 2023 9:01 am
But copper almost always has water issue from what I see?
