It is currently Fri Nov 20, 2026 2:56 pm
 Post subject: 273 2BBL Carb
PostPosted: Mon Feb 13, 2023 11:13 am
Car Model: Barracuda
Will a 1967 2 BBL carb work well on a /6 or is one from a 318 a better choice?
 Post subject: Re: 273 2BBL Carb
PostPosted: Mon Feb 13, 2023 6:11 pm
A '67 273 2bbl carb can be made to work well on a Slant-6, yes, assuming that carburetor is a good one, in good condition-repair-adjustment. That's the hardest part these days, is getting hold of a carburetor in good enough condition to be worth messing with. On the one hand, "remanufactured" carbs are almost always junk. On the other hand, the "100% NEW NEW NEW LOW-TOP HIGH-TOP NEW NEW NEW NEW!!!!!11!!!" Chinese imitations all over the internet are of dubious quality and safety. On the other-other hand, most original unmolested (never "remanufactured") carburetors are by this time so old that they have hard-parts wear extreme enough to need refurbishment far beyond just cleaning and putting in a rebuild kit (rebush the throttle shafts, de-warp the castings if possible, etc—done by a carburetor/machine shop with the needed skills and equipment).
I think I still have one or two new mid-'60s 2bbl carbs on the shelf (real ones as supplied by Chrysler, not the copycat junk); send me a PM if you're interested.
