It is currently Sat Nov 21, 2026 8:05 am
Post new topic  Reply to topic  [ 62 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Feb 18, 2023 2:26 pm
True, true.
He said most of his customers buy cheap heads from summit.
Then the spend another chunk putting better parts in them.
And of course porting and flowing.
I have been charting numbers that I have stumbled on.
It will be interesting to see if the trend on my head matches what I have found.
Funny thing, this head porter lives 5 minutes from my house.
And he has a big shop in the back yard, does all his work there.
PostPosted: Sat Feb 18, 2023 2:49 pm
I found my head flow info and (tried to) PM it to Rick a few hours ago. I would like to know what a stock "447" peanut head is good for.
My results were done on John's flow bench at 10", and was either cyl 3 or 4.
I have a thread here buried a few pages back in the "engine" section here, about my build//, skip the "war and peace" and go to the next to last post in the thread and my results are there. That's with the SI oversize valves after I made all the iron dust. I had that head shaved 70-thou and got the chambers to 49-50cc's. My first attempt at porting a head that I hope " counted" as prior to that is played with a couple of heads deemed scrap, due to having cracks in them. Those weren't /6 heads though. And I never had either of those flowed either. I know I was in pins and needles as the " band sawed head" seemed to be resurrected and posted right around the time I did the head whose results were shown in that engine rebuild thread.
PostPosted: Sat Feb 18, 2023 5:47 pm
https://www.slantsix.org/forum/viewtopi ... 60#p502160
PostPosted: Sun Feb 19, 2023 2:32 am
https://www.slantsix.org/forum/viewtopic.php?f=19&t=64775&p=502160#p502160
Thanks for highlighting that to bring it back up, wish I knew how. I've recently had a few people asking me for that flow info. I also wish I knew where that head started at, when it was as cast from the factory
PostPosted: Sun Feb 19, 2023 6:29 am
No problem.
I found a set of numbers from DT also searching for flow numbers.
I used a formula to convert your 10 to 28 inH2O also and put that in my matrix.
Just seeing what trends are across all the data is interesting.
I have that old head that had a compression problem still here.
I might put the 1.88 or 1.81 (don't remember) intake and 1.5 exhaust valves back in number 3 or 4.
I will take it to the porter when I pick up my other head and see what it flows.
If he doesn't charge me too much....
He told me the other day, I don't need any more work.
He was doing me a favor in his spare time.
PostPosted: Sun Feb 19, 2023 12:00 pm
Ixnay on the second head to the porter.
He called me a minute ago about the bottom row of intake exhaust studs.
Said he was 40 minutes in and still had not flowed any air.
He said if it was a SB chevy he could have done 2 sets of heads by now.
I am thinking this is the first and last of flow work by him.
PostPosted: Sun Feb 19, 2023 12:27 pm
Ixnay on head number 1.
He does not have a bore adapter small enough for my small chambers.
He has 4.0 and up and it over laps with head bolts and adjacent chamber.
Crap, I was looking forward to the data.
No good deed goes un-punished.
Whatever that means.
PostPosted: Sun Feb 19, 2023 2:04 pm
This is easy. Just drive up to John's with your heads, and I'll meet you down there with your 198 crank. :lol: :lol: :lol: :lol: :lol:
PostPosted: Sun Feb 19, 2023 4:07 pm
Easy?!?
You are a nut case!
John has everything in storage now anyway.
PostPosted: Mon Feb 20, 2023 10:59 am
It would be easy for me. :mrgreen:
PostPosted: Mon Feb 20, 2023 1:50 pm
Nut Case? For sure!! All of us are! :D :D
PostPosted: Mon Feb 20, 2023 2:04 pm
Easy?!?
You are a nut case!
Hey it was easy for me too.
And while I don't have a head that needs flowed/ evaluated right now (my own excluded, nevermind) I hope to run into him at the Indy swap coming up ..
PostPosted: Sun Feb 26, 2023 5:42 pm
So which era of cylinder heads are these numbers coming from? There is a least 4 different castings done over the years and I have a head from each era.
1) I have a 1963 head with the first generation of the chamber design. The ports neatly match the gasket and the runners have a nice flow to the valves. This may be a fluke, or the myth that yellow engines are better then red engines is true.
2) I have a version from 1974, but it is currently setting on top of the engine of our Duster. So I can't say how well it was casted.
3) I have a couple of heads from the 1976 - 1979 era. The runners need to be gasket matched and there is a definite difference in the port runners from the '63 head.
4) I have a head from 1980 and beyond. Once again they need to be gasket matched and the runners are designed differently from the others.
There must be a reason for the port runner changes. Is one era better then another?
PostPosted: Sun Feb 26, 2023 5:51 pm
I think my head is the "169" head and that is what Mike asked me to send for porting if I had one.
PostPosted: Sun Feb 26, 2023 6:13 pm
169 is a drool tube head, 67 to 74, with the chamber wall stood up more vertical than the earlier head.
On the spark plug side.
That chamber shape is better, I agree with Mike.
