It is currently Sat Oct 24, 2026 1:02 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 22, 2023 5:47 am
Here is what I did on my '69 Dart with a 225 Hyperpack..Similar issue to yours except for the choke linkages.
That post is over 10 years old.. good stuff.
Thanks Greg, I like the "nobody will ever see it" approach. What did you do to that air cleaner base? Looks like a pie plate so wasn't sure beyond the duct tape that you did ;)
Either Make you own base or Modify A cheap moroso one from a swap meet like i did.. It's Ugly as all hell no one ever sees it.
I stated with a Moroso aluminum base. I am not sure on the holes / duct tape.
I probably was expimeriting with air flow or something by adding holes then taping them back off.
there is also a big hole for the Fuel inlet or choke assembly on some carbs.. that seems to be taped off too.
The Moroso base was probably too high and possibly too large of a diameter for what I needed. The aluminum is nice and soft for hammering on to reshape. I didn't have as much metal shaping skills back then (in college or just out of college) as I do now. I might attempt to make a better or nicer piece if I cared about looks. I also have a welder so I could make virtually anything out of mild steel. (limited access to proper welding equip back when I was young)
Good luck!
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 16 guests
