It is currently Sat Oct 24, 2026 11:07 pm
 Post subject: Melling oil pump
PostPosted: Sat Mar 25, 2023 1:07 pm
Car Model: Fury I
I began putting my engine together after getting it back from the machine shop. The machine shop installed a new Melling P/N M-66C oil pump. I noticed the pump has one less mounting bolt and there is an "uncovered" area on the block. According to the Melling catalog it is the correct part number. Has anyone experienced this?
"Just think of all those Ford owners who will someday want an automobile."
John Francis Dodge
 Post subject: Re: Melling oil pump
PostPosted: Sat Mar 25, 2023 1:18 pm
Car Model: Fury I
I'm trying to post photos but they don't post
John Francis Dodge
PostPosted: Sat Mar 25, 2023 1:44 pm
Yup. Look around,lots of posts about the 5 bolt vs the original 6 bolt pump on the site
Lota are suggesting that you pull your original apart, inspect everything close, clean it out good and if it looks good to reuse your original oil pump.
Also so you can reuse the original oil pump drive gear that's already worn into your camshaft drive gear.
PostPosted: Sat Mar 25, 2023 2:09 pm
Car Model: Fury I
I thought about that but the original pump seems to be seized. I'm not so concerned about the one less bolt as I am about the hole. I wish I could post the photo.
John Francis Dodge
PostPosted: Sat Mar 25, 2023 3:46 pm
Double Post
PostPosted: Sat Mar 25, 2023 3:48 pm
Don't need to post pic, we've seen em
It seems all the semi recently manufactured new pumps for these engines are made that way.
I redid my engine late 21/early '22 and at the time I found a new but OLD stock oil pump for mine on eBay of all places. It's 6 bolt like the originals were. Many have used the 5 bolt pump it don't appear to hurt anything.
Users browsing this forum: Amazon [Bot] and 8 guests
